transmission tunnel
From adelaide
i want to put a sr20 in my 1200 ute and have been told the trans tunnel has to be bigger for clearence i have looked at the transmission tunnels that MADDAT are selling that you just weld in. but thats means i have to remove the heater box. any ideas on what i can do to be able to keep the original heater box in?
thanks
Posted on: 2010/4/20 12:42
Re: transmission tunnel
use a 120y tunnel or stanza if you dont mind bashing it into shape. use the 120y one and save some $$$
Posted on: 2010/4/20 12:52
From Geelong, Vic
or if you can find an auto 1200 one...they also work
Posted on: 2010/4/20 12:56
From adelaide
cheers mate. using the 120y tunnel is that gonna give me more room than the original trans tunnel in the ute
Posted on: 2010/4/20 12:59
From Geelong, Vic
yes, lots more
Posted on: 2010/4/21 1:47
I was lucky enough to score my coupe which was apparently an auto from factory. Still required a fair amount of "massaging" tog et to fit an an R30 gearbox. But is the R30 gearbox physically bigger or smaller than a CA/SR gearbox?
Posted on: 2010/4/21 5:39
