Re: which cam? tell me your experiences....
140 is just right with your injection by the sounds of it any smaller and you might as well keep your 70/30. Are you planning for a custom plenum/airbox?
Posted on: 2010/4/21 0:39
I've got the 140 in my A15/ Dellortos. It's a street car and is surprisingly good with mid range torque.
Very happy with the cam, I wouldn't go smaller if I were building another motor
Posted on: 2010/4/21 4:43
From Melbourne Vic
beautiful, well a 140 it is! i went down and spoke with clive cams, who used to be one of the brains behind wade and he will grind me up a 140 but with a lobe sep. of more like a 109 than the 106 they usually have to bring some extra low down drivability.
thanks all for your input!
Posted on: 2010/4/21 9:33
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Teh 140 was a pretty popular grind at one time for mini/bmc a series engines. there are those who will take exception to the 140, on the basis (as applied to minis) that it's got heaps fo duration (a good thing, and you definitely need a bit to get things moving in a higher rpm range) but that (relative to that much duration) the peak lift isn't earth shattering.
I'd make the point in response that for the street, less peak lift means the valvetrain will be under far less stress, slower opening and closing ramps, nice and 'considerate' to the valvetrain, which is a big deal. If it was just for competition use I'd argue the other way, but for this app - not a bad choice at all.
Posted on: 2010/4/21 11:11
John McKenzie
From South Africa, Bloemfontein
I will be keeping an eye out on this thread. Gonna need some info from you when you have tested your cam that you decide on Lagwagon.
Posted on: 2010/4/21 11:41
1977 Datsun 1200GX
From Perth
I've got a Clive 257B
Ask him his advice on that for a streeter :)
104 lob sep
309 thou lift at lobe
Exh opens 84 deg closes 59
Inlet opens 56 deg closes 87
261 deg duration
Posted on: 2010/4/21 12:29
From Perth WA AUS
I wish I knew what my cam specs are!
Posted on: 2010/4/21 13:30
Datsun 1200 2Dr sedan.
From Melbourne Vic
so you think taking the lobe separation from 106 to 109 is a good move or leave as is?
Posted on: 2010/4/21 13:38
From mandurah
your specs are gay haha !! now you know what your specs are haha
Posted on: 2010/4/21 13:40
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Melbourne Vic
freaking perth spam
edit: sorry half the valuable responses for this thread have been from perth boys! So no generalised location specific offence intended. just not a fan of useless stuff in useful threads!
Posted on: 2010/4/21 13:54
« 1 (2) 3 »
