stud pattern?
Not too shy to talk
From Darwin, NT
does anyone know if toyota celica (old style), fit on the 1200 ute. i can get some cheap, and they look good...any help would be great.....thanx
Posted on: 2003/11/14 5:20
Re: stud pattern?
From Melbourne, Australia
yeah old school toyota stuff fits, just measure 2 diagnol studs to check 114.3mm
Posted on: 2003/11/14 6:32
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: stud pattern?
114.3mm seems like a really odd size. Isn't it really an imperial size, like 4-5/8" or 4.625". I dont have my metric conversion calculator handy.
I think that it.s a bit co-incidental that two major manufacturers would come up with a "metric" PCD of 114.3mm at random
Chris
P.S. PCD = Pitch Circle Diameter, or the doameter of a circle that passes through the center of all the studs.
Posted on: 2003/11/14 12:05
Re: stud pattern?
From Okinawa, Japan
114.3mm = 4.5 inches.
Posted on: 2003/11/14 12:51
Re: stud pattern?
you wouldnt think mitsubishi would use it either but hey they did
Posted on: 2003/11/14 14:58
1200 Coupe Rallycar
Re: stud pattern?
From sydney australia
just how old school?ke20 corrollas all seemed to be 4 x 100,cause all the supersprinters i knew used mazda 13 inch rims,with that stud pattern.they changed to 114.3 X 4 in the ke30's.
Posted on: 2003/11/16 5:56
Re: stud pattern?
"old school" in this context means "rear-wheel drive".
And yes, Datsun and Toyota previously used 4.5" wheel centers rather than metric sizes. I wonder if this was because they made vehicles under license from British manufacturers.
Posted on: 2003/11/16 19:18
