help any one please
Quite a regular
From brisbane
i want 2 put 17x6.5 rims on my completly stock datsun 1200 79 ute is there any complications other than the guards being rolled coz im gunna get that done
Posted on: 2010/4/27 8:23
Re: help any one please
What offset are they mate? Depending on that, they may well fould on the struts or inner guards when turning...
Posted on: 2010/4/27 8:30
Quite a regular
From brisbane
i want to buy some rims for the tempe tyre website but i dont want to buy them if it is not going to work out or to much stuffing around
Posted on: 2010/4/27 8:33
Quite a regular
From brisbane
not sure i will find out thanks mate
Posted on: 2010/4/27 8:34
Quite a regular
From brisbane
i called them the y said 20 or 40 offset
Posted on: 2010/4/27 8:37
Quite a regular
From brisbane
which one is beter because im getting the outer guards rolled and pumped so the outer guards wont be a problem
Posted on: 2010/4/27 8:41
From Sydney, Australia
Offset of 20 or 40 ?.. they've got NO idea. (For which I'm definitely not surprised).
6.5 inch rims of any diameter will barely fit on a 1200 at the front, and I reckon the ET would be closer 15mm (but even I'm guessing).
You really need to get all your strut/brake upgrades done before spending a lot of money on wheels. Because if you buy wheels first, the wheels won't fit if you when you are done changing brakes/hubs/struts.. because inevitably the front track width changes +/-20mm.
With 17s you'll need to:
- cut the front corner of the guard
- roll the lip
- section the footwell.
Other people make it look easy..they don't talk about how much work it is.
I wouldn't recommend buying from Tempe Tyres, unless you are in Sydney and can take stuff back.
Posted on: 2010/4/27 11:08
From Perth
Never buy a wheel unless you can do a trial fit
And don't put big wheels on a car without decent disc brakes
Posted on: 2010/4/27 11:34
Quite a regular
From brisbane
what brake and strut upgrades do you reccomend then
Posted on: 2010/4/27 13:02
1200 coupe struts, with the good disc brakes.
And 165/55 R12 tires is what I use. Or if you want bigger, 185/50 R14.
Posted on: 2010/4/28 4:29
