oil cooler advantages
From sutho shire
hay just wondering what the advantages of runing a oil cooler are.. would love some info as im pending on running one..
Posted on: 2003/11/14 18:45
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: oil cooler advantages
From Tas
They are usually used in high load / stress situations. Found usually on auto trans if the car does a lot of towing, mainly due to auto fluid being.......well.....auto fluid really.
As for engine oil cooling - you very rarely see it done on small 4 cylinders, I spose because you can simply buy very high quality oil these days that can sustain very high temperatures.
With oil you get what you pay for.............
I hope this helps in some way
Posted on: 2003/11/15 0:02
From Pakistan
OIL COOLErS COULD B USEFUL IF u TURBOCHARGE A na ENGINE to produce about twice as much power, as its oil system is not built with turbo heat in mind. u can also check oil temp of fully warmed engine indepndently of coolant temp and c if its ok with the oil spec. again if r using synthetic oil u could get away without oil cooler imo.
Posted on: 2003/11/15 19:04
STRONG IS STRONGEST ALONE. PERIOD
Quite a regular
From melbourne
Yea my brother runs an oil cooler on his stanza rallycar,the idea is cooling the oil in your engine as well as the water in it is a lot more effective than just cooling the water.It is another way of fixing overheating problems but doesn't work if your radiator is dead.
Posted on: 2003/11/15 23:19
You'll find that a lot of older turbo 4's run an oil cooler out of the factory, such as a pulsar et. I think its just due to the fact that turbo's heat the oil to rediculously high temperatures. I think they are a good idea on any turbo'd car.
Posted on: 2003/11/16 3:10
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
