t28 not spooling??
Quite a regular
From melbourne
hey im running mazda 1300 with a 1.4 bored 25 tho tx3 turbo pistons custom grind turbo cam with ford center point fuel injection. its runnin a nissan t28 turbo and its not boosting? i put new acuator on it and it's spooling but not creating any boost? it hits 10 vacume on the guage and just completely stops pulling and starts to drown itself in fuel?
can someone please let me know how i could try n fix this?
Posted on: 2010/5/5 10:21
Re: t28 not spooling??
does ur motor have enough cub's to push the turbo ?
is the exhaust wheel in working order ?
Posted on: 2010/5/5 11:16
1200 ute unfinish'd sr20 $$$
1200 ute stocko
bumble bee drift pig
XR8 tow car / daily
bailz is orsum
From Geelong, Vic
what sorta nissan is the t28 off? if its a pulsar one it would be pretty laggy as they have the large (.86 ??) rear housing
Posted on: 2010/5/5 11:22
Quite a regular
From melbourne
Im not 100% sure all I know its a nissan and yeah its lagy as #OOPS# but it was boosting at 11 psi then died.. Should I pull the cooler pipe off on the other side of the cooler and see if its pushing through? Could have snapped the shaft between housings? Im new to the turbo world..
Posted on: 2010/5/5 13:23
could of said that to start with .
1 vote with missing exhaust wheel
Posted on: 2010/5/5 22:47
1200 ute stocko
XR8 tow car / daily
bailz is orsum
PIGDOG: It does depend on which of the T28 series you have but mine is off an S15 and it has the .86 housing...
I wouldnt go missing exhaust wheel but it could have let a few impellers go, a snapped shaft is possible but only if there was insane amount of shaft play...
What kind of ondition was the turbo in when you put it on mate? And is it a BB type (S15) or a floating type?
IGDOG can u remeber if the Pulsar ones were floating or not...? Will see what i can find
Posted on: 2010/5/5 22:52
From Sydney, Australia
With the engine turned off, take the front intake hose off the turbo and try to spin the impeller.
If it doesn't turn, the rear oil seal in the turbo has slowly leaked and filled the exhaust wheel up with hard oil (coke) crap.
This stops the wheel from turning. I had an S14 turbo that did that on my old ca18.
Posted on: 2010/5/5 23:04
Quite a regular
From melbourne
Thanks for that.. Another thing I put my hand over the intake of the turbo and it still has a fuk load of preasure sucking on my hand? Got me buggard what it is.
Posted on: 2010/5/6 13:43
You put your hand over the turbo intake?
Be careful doing that, a member here lost his finger(s) doing the same thing...
Posted on: 2010/5/6 14:04
If you say it did boost up to 11psi, then it should be still doing it. You say it stoll creates a vaccuum on the turbo intake, so the wheels are still spinning.
It cis most likely a post-turbo intake leak. Thing like split hoses, hoseclamps not tight enough, split intercooler, split custom intake manifold are all possible causes.
If it's overfueling then maybe it's an ignition or tuning problem?
It's a bit mysterious. I also would think that a t28 was too big for a 1300-1400cc engine.
Posted on: 2010/5/6 22:14
