Re: ca18det fitting into ute
From Nyngan, nsw Australia
if you just purchase the x-member and mounts from them, you'll need there g/box tunnel aswell, my engineer said 10mm clearence off back wall, but ive gone 25mm to allow all pipe run around the back of the motor...still plenty room up front for the cooler/radiator
Posted on: 2010/5/9 0:19
living is good,.....
Subject Poster Date
     ca18det fitting into ute bfunkdlux 2010/5/8 9:59
       Re: ca18det fitting into ute frankthedolphintrainer 2010/5/8 10:06
         Re: ca18det fitting into ute bailz 2010/5/8 10:07
       Re: ca18det fitting into ute bfunkdlux 2010/5/8 10:22
       Re: ca18det fitting into ute frankthedolphintrainer 2010/5/8 10:25
         Re: ca18det fitting into ute Jordan 2010/5/8 10:54
       Re: ca18det fitting into ute supafatto 2010/5/8 11:10
       Re: ca18det fitting into ute bailz 2010/5/8 15:43
         Re: ca18det fitting into ute dattopower 2010/5/8 23:44
       Re: ca18det fitting into ute Dat82 2010/5/9 0:17
         Re: ca18det fitting into ute ZigZag 2010/5/9 0:22
       Re: ca18det fitting into ute hotrocket 2010/5/9 0:19
         Re: ca18det fitting into ute Dat82 2010/5/9 0:30
       Re: ca18det fitting into ute datto13b 2010/5/9 0:56
         Re: ca18det fitting into ute blob 2010/5/9 1:37
           Re: ca18det fitting into ute Dat82 2010/5/9 1:44
             Re: ca18det fitting into ute bfunkdlux 2010/5/9 2:00
             Re: ca18det fitting into ute blob 2010/5/9 5:37
               Re: ca18det fitting into ute Dat82 2010/5/9 7:13
       Re: ca18det fitting into ute dattopower 2010/5/9 1:01
       Re: ca18det fitting into ute bfunkdlux 2010/5/9 1:10
       Re: ca18det fitting into ute hotrocket 2010/5/9 1:15
         Re: ca18det fitting into ute bfunkdlux 2010/5/9 1:18
           Re: ca18det fitting into ute dattopower 2010/5/9 1:23
       Re: ca18det fitting into ute datto13b 2010/5/9 1:19
         Re: ca18det fitting into ute PIGDOG 2010/5/9 1:26
       Re: ca18det fitting into ute bfunkdlux 2010/5/9 1:32
       Re: ca18det fitting into ute perthute 2010/5/9 2:24
       Re: ca18det fitting into ute bailz 2010/5/9 4:42
         Re: ca18det fitting into ute bailz 2010/5/9 4:44
       Re: ca18det fitting into ute tommo73 2010/5/9 5:03
       Re: ca18det fitting into ute Fenix_Longbow 2010/5/9 7:23
         Re: ca18det fitting into ute Dat82 2010/5/9 7:46
       Re: ca18det fitting into ute Fenix_Longbow 2010/5/9 11:34
       Re: ca18det fitting into ute estyre 2010/5/9 12:17
       Re: ca18det fitting into ute PIGDOG 2010/5/9 14:56
       Re: ca18det fitting into ute hotrocket 2010/5/9 22:13
       Re: ca18det fitting into ute go1200 2010/5/10 6:10
       Re: ca18det fitting into ute bfunkdlux 2010/5/10 10:57
