Re: ca18det fitting into ute
yeah ive got the trans tunnel as well but there is no way with the gearbox mounted in the correct position that the engine is gunna clear the firewall, after satring at it for a few hours it looks like it needs to come forward about 10 mm and maybe sit down 5-10mm too. not sure if i want to cut the maddat welds and reweld thats sort of why i bought it in the first place, so it would fit without any issues
Posted on: 2010/5/9 1:10
finally gettin the ca18 ute project underway
Sunny’s were made to be drifted, it says so in the factory service manual: Service after every drift day and mountain tounge or 100,000km’s
Subject Poster Date
     ca18det fitting into ute bfunkdlux 2010/5/8 9:59
       Re: ca18det fitting into ute frankthedolphintrainer 2010/5/8 10:06
         Re: ca18det fitting into ute bailz 2010/5/8 10:07
       Re: ca18det fitting into ute bfunkdlux 2010/5/8 10:22
       Re: ca18det fitting into ute frankthedolphintrainer 2010/5/8 10:25
         Re: ca18det fitting into ute Jordan 2010/5/8 10:54
       Re: ca18det fitting into ute supafatto 2010/5/8 11:10
       Re: ca18det fitting into ute bailz 2010/5/8 15:43
         Re: ca18det fitting into ute dattopower 2010/5/8 23:44
       Re: ca18det fitting into ute Dat82 2010/5/9 0:17
         Re: ca18det fitting into ute ZigZag 2010/5/9 0:22
       Re: ca18det fitting into ute hotrocket 2010/5/9 0:19
         Re: ca18det fitting into ute Dat82 2010/5/9 0:30
       Re: ca18det fitting into ute datto13b 2010/5/9 0:56
         Re: ca18det fitting into ute blob 2010/5/9 1:37
           Re: ca18det fitting into ute Dat82 2010/5/9 1:44
             Re: ca18det fitting into ute bfunkdlux 2010/5/9 2:00
             Re: ca18det fitting into ute blob 2010/5/9 5:37
               Re: ca18det fitting into ute Dat82 2010/5/9 7:13
       Re: ca18det fitting into ute dattopower 2010/5/9 1:01
       Re: ca18det fitting into ute bfunkdlux 2010/5/9 1:10
       Re: ca18det fitting into ute hotrocket 2010/5/9 1:15
         Re: ca18det fitting into ute bfunkdlux 2010/5/9 1:18
           Re: ca18det fitting into ute dattopower 2010/5/9 1:23
       Re: ca18det fitting into ute datto13b 2010/5/9 1:19
         Re: ca18det fitting into ute PIGDOG 2010/5/9 1:26
       Re: ca18det fitting into ute bfunkdlux 2010/5/9 1:32
       Re: ca18det fitting into ute perthute 2010/5/9 2:24
       Re: ca18det fitting into ute bailz 2010/5/9 4:42
         Re: ca18det fitting into ute bailz 2010/5/9 4:44
       Re: ca18det fitting into ute tommo73 2010/5/9 5:03
       Re: ca18det fitting into ute Fenix_Longbow 2010/5/9 7:23
         Re: ca18det fitting into ute Dat82 2010/5/9 7:46
       Re: ca18det fitting into ute Fenix_Longbow 2010/5/9 11:34
       Re: ca18det fitting into ute estyre 2010/5/9 12:17
       Re: ca18det fitting into ute PIGDOG 2010/5/9 14:56
       Re: ca18det fitting into ute hotrocket 2010/5/9 22:13
       Re: ca18det fitting into ute go1200 2010/5/10 6:10
       Re: ca18det fitting into ute bfunkdlux 2010/5/10 10:57
