Re: ca18det fitting into ute
im using a ca box, the ca g/box tunnel and the ca g/box mount mounted to the maddat g/box crossmember as described by madat. if you lean the engine forward to give, say 10 mm clearence with the firewall the tailshaft will be running through the cab (probably not the best idea for legal reasons lol)
Posted on: 2010/5/9 1:32
finally gettin the ca18 ute project underway
Sunny’s were made to be drifted, it says so in the factory service manual: Service after every drift day and mountain tounge or 100,000km’s
Subject Poster Date
     ca18det fitting into ute bfunkdlux 2010/5/8 9:59
       Re: ca18det fitting into ute frankthedolphintrainer 2010/5/8 10:06
         Re: ca18det fitting into ute bailz 2010/5/8 10:07
       Re: ca18det fitting into ute bfunkdlux 2010/5/8 10:22
       Re: ca18det fitting into ute frankthedolphintrainer 2010/5/8 10:25
         Re: ca18det fitting into ute Jordan 2010/5/8 10:54
       Re: ca18det fitting into ute supafatto 2010/5/8 11:10
       Re: ca18det fitting into ute bailz 2010/5/8 15:43
         Re: ca18det fitting into ute dattopower 2010/5/8 23:44
       Re: ca18det fitting into ute Dat82 2010/5/9 0:17
         Re: ca18det fitting into ute ZigZag 2010/5/9 0:22
       Re: ca18det fitting into ute hotrocket 2010/5/9 0:19
         Re: ca18det fitting into ute Dat82 2010/5/9 0:30
       Re: ca18det fitting into ute datto13b 2010/5/9 0:56
         Re: ca18det fitting into ute blob 2010/5/9 1:37
           Re: ca18det fitting into ute Dat82 2010/5/9 1:44
             Re: ca18det fitting into ute bfunkdlux 2010/5/9 2:00
             Re: ca18det fitting into ute blob 2010/5/9 5:37
               Re: ca18det fitting into ute Dat82 2010/5/9 7:13
       Re: ca18det fitting into ute dattopower 2010/5/9 1:01
       Re: ca18det fitting into ute bfunkdlux 2010/5/9 1:10
       Re: ca18det fitting into ute hotrocket 2010/5/9 1:15
         Re: ca18det fitting into ute bfunkdlux 2010/5/9 1:18
           Re: ca18det fitting into ute dattopower 2010/5/9 1:23
       Re: ca18det fitting into ute datto13b 2010/5/9 1:19
         Re: ca18det fitting into ute PIGDOG 2010/5/9 1:26
       Re: ca18det fitting into ute bfunkdlux 2010/5/9 1:32
       Re: ca18det fitting into ute perthute 2010/5/9 2:24
       Re: ca18det fitting into ute bailz 2010/5/9 4:42
         Re: ca18det fitting into ute bailz 2010/5/9 4:44
       Re: ca18det fitting into ute tommo73 2010/5/9 5:03
       Re: ca18det fitting into ute Fenix_Longbow 2010/5/9 7:23
         Re: ca18det fitting into ute Dat82 2010/5/9 7:46
       Re: ca18det fitting into ute Fenix_Longbow 2010/5/9 11:34
       Re: ca18det fitting into ute estyre 2010/5/9 12:17
       Re: ca18det fitting into ute PIGDOG 2010/5/9 14:56
       Re: ca18det fitting into ute hotrocket 2010/5/9 22:13
       Re: ca18det fitting into ute go1200 2010/5/10 6:10
       Re: ca18det fitting into ute bfunkdlux 2010/5/10 10:57
