« 1 (2) 3 4 5 »
#11 Re: engine rebuild kits
clyons8 Posted on: 2010/5/4 14:09
Looking for prices for the following;
Piston Rod Option 1 >
A12 +60thou (74.5mm?) pistons with between 5cc - 10cc dish, full floating with bushed rods to match. To work in hand with my high comp GX head (currently 20cc chambers).
Piston Rod Option 2 >
A12 oversize 76mm flat tops, full floating with bushed rods to match.
Also interested in pricing for;
Con rod bearings, Mains Bearing, Cam bearings.
Complete A12 Gasket Kit.
Funds are very low at the moment as I have just bought a disc brake setup. What sort of time-frame are you looking to order?
#12 Re: engine rebuild kits
SX-510 Posted on: 2010/5/4 15:26
I'd be up for an A15 rebuild kit at those sorts of prices. Happy to go for higher than std comp pistons if that's what the majority are doing
#13 Re: engine rebuild kits
bige Posted on: 2010/5/5 10:02
clyons8 pm sent cheers
#14 Re: engine rebuild kits
bige Posted on: 2010/5/9 12:23
any more interests pm me
#15 Re: engine rebuild kits
m_amery Posted on: 2010/5/10 1:42
So these kits include all required seals and just everything that's needed to rebuild the engine back to the stock standard?
#16 Re: engine rebuild kits
clyons8 Posted on: 2010/5/10 2:02
BigE is a reputed A Series race engine builder. These kits are for stock motors, worked motors and all out race monsters. The prices are really quite good.
#17 Re: engine rebuild kits
m_amery Posted on: 2010/5/10 2:34
Count me in for one if you do a bulk order. Rather keen.
#18 Re: engine rebuild kits
bige Posted on: 2010/5/10 3:50
need more info on what engine combos u are after. eg a12/a14/a15 hi comp.std etc u can pm or call me 0412 864 741 ps need to get numbers of same type of kits to order in bulk.cheers
#19 Re: engine rebuild kits
thedevilshands Posted on: 2010/5/10 7:17
bige: I will be keen for a hi comp a14 package when the final numbers are in (I too am poor like clyons). Unsure of diameter pistons I need but fairly sure block is stock atm.
#20 Re: engine rebuild kits
bige Posted on: 2010/5/10 8:05
OK . getting close in orders 1ST UP is for A14 kits hi comp pistons. {$420 + freight} Need to confirm orders. PM ME OR RING to place orders & need sizes. Pistons will be +1mm/+1.5mm oversize, bearings can be std/.25mm/.5mm undersize.gaskets, cam bearings std. I would like to place order soon {20 sets is min} .big outlay for me. {serious people, no tyre kickers}deposit money get kit. lets go cheers.
« 1 (2) 3 4 5 »
