« 1 2 (3)
Re: How to lowered 1200?(with pillowball)
From Malaysia
Any1 hv comparison pix of B210 vs B310 strut???
Posted on: 2010/5/12 8:52
B110 1972 Modded A15
From Geelong, Vic
if you actually want to do it properly, go get some 180b struts, which are very different to 120y struts. and similar to sunny(b310) struts but better. straight away you will have more suspention travel like whitesedan said
but then to be even better you can get some r31, z31, 240z ect inserts then cut the strut tube down to suit. this will give you more available suspention travel and shock inserts that are suited to a bit heavier spring rates
Posted on: 2010/5/12 9:06
From Malaysia
Thanks for replying..
Im in tight budget...
BTW those 180b or 240z strut r quite hard to get in our place..
Im looking for those pnp or slight mod strut like B210...
Can any1 point me some pix of the b210 vs b310 strut comparison??
Posted on: 2010/5/12 9:15
Posted on: 2010/5/12 11:07
From Malaysia
Thanks unfamilia...
But B210 strut is not the same as B110 rite?(diameter is smaller)
But from the pix,the spring seat height looks the same...
Posted on: 2010/5/12 13:15
« 1 2 (3)
