« 1 (2)
Re: laden and unladen weight
From SE Melbourne
I'd guess that's the car with all fluids, but no people in it...
GVM is the car fully loaded with people and cargo - not sure what the carrying capacity of a 1200 is meant to be probably about 400kg?
Posted on: 2010/5/13 15:06
Mildman, Datsunless
Not too shy to talk
From Katherine N.T.
thanks mildman, saved me alot of stress.
so how would one determine the weight of four passengers and cargo? lol.
Posted on: 2010/5/14 7:10
From SE Melbourne
Average passenger has to be around the 70-80kg mark, I don't think it would expect more than 200kg of load on top of that...
So a guess of GVM could be weight + 80x4 + 200 = 520 on top of kerb weight.
All our corner weights at work are quoted with a driver inside, and GVM tells us what to load the car up to (we weigh it in our weighbridge unloaded to work out how many sandbags to chuck inside)
Posted on: 2010/5/14 9:30
Mildman, Datsunless
Quite a regular
From Sydney NSW
748kg, no wonder that tiny four feels as smooth as a big six.
Posted on: 2010/5/14 11:57
Not too shy to talk
From Katherine N.T.
interesting? i will approach the weigh bridge boys on this one aswell i think. im not too sure how clued up or even intelligent they are up here for that matter. thanks for all your input guys, has been helpful.
Posted on: 2010/5/15 1:51
From Canberra
This is from wikipedia: Tare weight, sometimes called unladen weight, is the weight of an empty vehicle or container.
I know when I rang up the motor registry in the ACT they said that the heaviest model in the 1200 range (the wagon) had a tare weight of 720kg and the utes weigh 690kg so I guess it would be somewhere around this.
Posted on: 2010/5/15 2:04
YLD.18L
From SE Melbourne
Yeah the Americans might use a different system...as I though 745 was a little high - but I've never actually weighed mine - the tip has a scale that must be at least +/- 20kg in resolution.
Although i remember with a skyline I had the tare weight was about 100kg less than the car really weighed
Posted on: 2010/5/15 4:23
Mildman, Datsunless
Not too shy to talk
From Katherine N.T.
so all in all how much do you all think a standard 1200 coupe would weigh? over 700kg or below?
Posted on: 2010/6/12 15:38
From NZ
Book says 710kg
Posted on: 2010/6/13 12:34
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
Not too shy to talk
From Katherine N.T.
awww yea! cheers man
Posted on: 2010/6/14 5:23
« 1 (2)
