pushrods..
From Freo
and here they are..
Posted on: 2010/5/21 11:03
A15 PSI Project Motor
'72 CB750k,
Re: pushrods..
From Perth
OK... which is which then ?
Posted on: 2010/5/21 11:41
Re: pushrods..
From Freo
short to long.. 10, 12-13, 14-15...
Posted on: 2010/5/21 13:03
'72 CB750k,
Re: pushrods..
Length
It is important to use the correct length for proper Rocker geometry. If the cylinder head is skimmed beyond the service limit, or the block deck is cut down, custom push rods are needed.
• 141.5 mm: A10 engine
• 152 mm: short-deck engines (A12, A12A, and 1980 A13)
•~167 mm: tall-deck engines (A14, A15, and 1974 A13)
Custom pushrods made to length from VW pushrods and using the A-series cup. They sit the turned down cup shaft on a ledge in the alloy. Custom made to your length and cheap.
Posted on: 2010/5/21 19:02
Edited by ddgonzal on 2010/5/21 23:04:39
« 1 (2)
