« 1 (2)
Re: fuse for lights
From brissie
yep checked it no corosion there and it is blowing 15A fuse. as soon s the lights go on i gets hot as! not to mention the high beams you cant touch it... then pop fuse gone.
Posted on: 2010/5/20 11:54
A12,4spd, mild cam ,head work, mags.
Re: fuse for lights
From Perth WA AUS
Best bet is to open the wiring loom seperate the wires so you can see what is what and replace the wires and connectors to the lights, extra earth will help if in doubt. The issue seems to be resistance and this creates heat so bad earth, corrosion or bad connections should be rectified, maybe add a relay aswell but only after checking the above.
Posted on: 2010/5/20 12:11
Datsun 1200 2Dr sedan.
Re: fuse for lights
From brissie
yeah i have to find where the earth is for the lights. im thinking that is the problem.
Posted on: 2010/5/20 12:28
Re: fuse for lights
From Perth WA AUS
You might be suprised how far your wiring has corroded on the actual wires, it is getting old.
Posted on: 2010/5/22 12:59
Re: fuse for lights
From mandurah
yes my spare harness is brital as and the insulation falls of if you bend the wire too much ,and it has green rot at all the crimps and joins !
Posted on: 2010/5/22 14:37
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
« 1 (2)
