(1) 2 3 »
The super strong A-series... FAIL
From South Africa
Years of 8000+rpm came to an end... I opened the motor due to dropped compression on NO2, kept driving the car for 3 weeks (i do about 90km a day)till I had a spare bottom end ready to go, was expecting a cracked ring but was a touch confuzed as there was no blow by or anything... car ran 100%, plugs looked fine, just much lower comp on NO:2
Opened the motor to find this,,, one nicely bent rod, and its been bent like this for some time by looking at the carbon ring on the bore... hats off to Datsun! even as a mech engineer, i was never expecting somthing like this due to how well she was still going, Piston was 10mm below deck!
jpg  PICT4348 (Large).JPG (78.03 KB)
9082_4bfab7b6df634.jpg 1024X768 px
Posted on: 2010/5/24 18:35
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
Re: The super strong A-series... FAIL
So it didn't really FAIL did it.
'one nicely bent rod' - it certainly is! did it even look like it was about to break?
Posted on: 2010/5/24 23:19
what does the bore look like now?
Posted on: 2010/5/25 0:07
Where the rods prepped Rezlo? Its no fail at all by the sounds of it,
everything is still fine inside.
If the rods a little beefier from Nissan or where aftermarket items,
The A would be seriously bullet proof.
Compare the ca18et rods to det (the et look like the a series)
The factory DET rods are definitely stronger than A series.
jpg  ca18et rods.jpg (66.21 KB)
737_4bfb0eec5d57f.jpg 640X535 px
jpg  ca18detvsca20.jpg (70.40 KB)
737_4bfb0ef66f4bc.jpg 800X600 px
Posted on: 2010/5/25 0:28
Edited by D on 2010/5/25 0:44:26
Yep,the A-series just keeps on running when lesser engines stop with a bang.
Posted on: 2010/5/25 1:32
From Freo
ahh Press it straight, bang it back in.. ha ha
Posted on: 2010/5/25 2:15
A15 PSI Project Motor
'72 CB750k,
From Albany, Perth Australia
should just put a new rod on and away you go again
Posted on: 2010/5/25 2:25
1200 Smerf Mobile
From Seattle ,WA.
so what would of caused the rod to bend like that,pre-ignition, slapping the valves ???
Posted on: 2010/5/25 3:38
From Sydney
All you have to do now, is to bend the other 3 to match, and then your ready to turbo the engine. IMO it's not quite a FAIL as yet......
Posted on: 2010/5/25 3:55
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
so what would of caused the rod to bend like that?
Tons of force, courtesy of NO2 -- nitrous oxide
Posted on: 2010/5/25 4:35
(1) 2 3 »
