« 1 2 (3) 4 5 6 »
#21 Re: Single Dellorto setups
clyons8 Posted on: 2010/5/26 4:57
Now that is tricky!
In terms of difficulty the manifold flange swap would be more difficult, it brings the manifold to the same bolt pattern as the head but the manifolds runners are still round port and the head still oval. Meaning it will all flow only as fast as the round ports & runners will flow.
Do you want me to get some prices to get bigger valves installed + full head recondition + mild port work on intakes?
I reckon you should throw all the gear onto an A12 round port head and get it onto the engine. Do you have someone to help you do this?
#22 Re: Single Dellorto setups
Posted on: 2010/5/26 5:18
talk with simon, sikyne again- if any one could make such a flange, im sure it would be him.
good ideat too, and the extra spacing would be like extra length in the runners.
#23 Re: Single Dellorto setups
thedevilshands Posted on: 2010/5/26 5:19
Yeah mad tricky solution Wurzel!!
I agree with Clyons.
Late a12 head will bolt str8 onto the "big blocks" use single round port manifold and away u go easy as.
IIRC (and I may not)
A12 head = single bolt above intake
A14/15 = twin bolt either side
Can drill and tap either head type to have both sets of holes.
Head swap is so easy, really its childs play, just need a Gregorys or somethin to point ya in the right direction and someone to talk you through setting the rocker-pushrod clearances.
A simple trick is Rock Cylinder #4 Set #1
(By rock I mean when u move the crank back and forward/left and right the in/ex pair of valves for that cylinder move up and down. If u got it wrong then only in or ex will move as you move the crank back and forward.)
Rock 4 set 1
Rock 3 set 2
Rock 2 set 3
Rock 1 set 4
Easy as mate.
Cheers, Jon
#24 Re: Single Dellorto setups
Wurzel Posted on: 2010/5/26 5:30
ha probably not at the moment! Im in my off work season so Ive got all the time to sit around and think of stuff like this...but the downside is low cash so im not sure I could afford the full works. A Good time to aqquire the parts and knowledge though...
So what would be the point of porting any part of the head or manifold if the runners stay the same? Would putting a round port head without porting on an a15 choke it, even with bigger valves?
Maybe the lynx is better off left to a12 or a10s. Maybe I could learn to make my own damn manifolds ;)
#25 Re: Single Dellorto setups
Wurzel Posted on: 2010/5/26 5:45
Thanks Jon Ill keep that in mind.
With the flange Idea It almost makes me think you could make whole manifolds this way...like a lamination process using multiple "sheets" of aluminium and just file away the difference and angles as you go. Would be a slow and labourious task, but you could get some mad lynx-style crossovers happening!
Its a pity cos the lynx manifold I have has had some kind of uneven work done to one of the ports and the edges filed to fit the exhaust manis, so it would have been good to chop it off and start all over again!
#26 Re: Single Dellorto setups
clyons8 Posted on: 2010/5/26 6:01
#OOPS# so the manifold is pretty rough? Sorry if that's the case especially seeing as I talked you into it.
Mate go the round-port head I have a heap of crap ones here that you can try porting yourself.
AN OZITO high speed router, dremel, engraver is available from Bunnings for AU$50.00 and there are also a heap of other stone bits there for sale individually.
Get some crap heads and have a go yourself, you can have the #OOPS#ty ones I have here for free. I would lend you my Dremel tool but it's all the way up in the tropics, right smack bang on the equator where I'd rather be.
When you feel you are confident enough to enlargen the ports on both the intake and the head then go for it. Take your time and do all ports at the same time bit by bit. No point going to town on one port then not knowing how far to go on the next.
Then put together a few hundred bucks and get bigger valves installed.
Bigger round ports will pull some good horsies, and I actually think this'd be a more suitable street engine than some of the more worked beasts around.
elemental_funks B10 and round port A15
#27 Single Dellorto setups
Dundee1000 Posted on: 2010/5/26 6:13
Cad drawing
I modelled this up for all of the above reasons, just don't have a 5 axis NC any more..
#28 Re: Single Dellorto setups
clyons8 Posted on: 2010/5/26 6:46
Those look good Mike.
I keep getting confused with the manifold that Wurzel has and the other cannon manifold.
I said that it may be difficult to port but you'd have to have a good look at it because you many be able to do it.
Here is what sidedraught had to say about these manifolds;
The "Lynx Crossover" is a unique induction manifold designed to obtain maximum efficency from a twin choke side draught carburettor on a 4 cylinder 4 port cylinder head. Conventional manifolds connect venturi "A" to cylinders 1 and 2 and venturi 'B' to 3 and 4. When applying either of the typical four cylinder firing orders, 1234 or 1342, each venturi feeds 2 consecutively firing cylinders. This results in two induction pulses followed by two static periods. The "Lynx Crossover" manifold is unque in that it connects venturi 'A' to cylinders 2 and 3 and venturi 'B' to 1 and 4, ie to alternatively firing cylinders. The "crossover" therefore spaces the induction pulses evenly. Seperated by static periods. It is in this situation that the side draught carburettor was designed to operate effectively as with twin side draught carburettors where each venturi feeds only one cylinder.
#29 Re: Single Dellorto setups
Wurzel Posted on: 2010/5/26 7:34
Interesting reading thos links.
Its all good Chris, It was only after getting it that I check it out closely enough to see something might be up with it, so its my bad. The good part is that after all this and seeing Dundees plans and elementalfunks b10. Im convinced this is a great way to go.
Bbeing a jeweller(well, part time) I'm pretty well equipped with dremels, dentist drills and guff to do the job...
Ive also been known to have a good eye for detail and a steady hand at times too...just not with ebay it seems :)
Ive been looking forwards to giving it a go for a while now.
But, like you said, if your air intake is only as good as the size of the runners, what good would porting out the head do?
Dundee, do you have .Dxf or similar file for the both the head and carby flange profiles?
#30 Re: Single Dellorto setups
Dundee1000 Posted on: 2010/5/26 9:23
TnPShow's website has the Manifold drawings, and the Carby flange I found specs on the new somewhere...
« 1 2 (3) 4 5 6 »
