WTB - 79-85 1200 Ute Radius Rod Mounts same as HB/PB 210
From ACT
As per title, cant seem to change the title in the other thread I posted
Need radius/caster/castor rod mount (lil sheet metal box thing the rod goes through and bushes on either side at front of car)
Any one got a ute from that era they are wrecking or HB210/PB210 (Sunny Excellent)?
Many thanks, Jon
Posted on: 2010/5/26 6:39
Now riding dirtbikes:
Lots of A series Datto stuff for sale
Re: WTB - 79-85 1200 Ute Radius Rod Mounts same as HB/PB 210
I was looking in the parts catalog
Bushings are the same 1200/B210/B120. B210 has part number for bracket, while 1200s do not (must be sold as part of the body piece?).
So I think you can fit the B210 bar in a 1200. When mine broke on my 1200, the body shop (panel beater) made a new one out of sheet metal and welded it right in place.
Posted on: 2010/5/27 9:30
From ACT
Thanks DD, I think I might be asking a bit much. As you say the mounts will have to be cut off the body, so its really bits off wrecks that I'm after.
I'm chasing these mounts because they create a different angle to the aussie B210 ones.
Apparently the L series PB210 from japan used these mounts with 180B/610 radius rods to balance the weight of the heavier motor on the 180B x-member in the B210 chassis ("davie" kindly provided this information).
Any one got any thoughts or wrecks?
Cheers, Jon
Posted on: 2010/5/27 10:18
From ACT
was gonna bump bogdog's L20B stroker thread cos that engine look schweet!!!
BUT...
Come on someone gotta have a 79-85 ute wreck they wanna cut the radius mounts off??
Anyone??
Lol
Bump ;)
Posted on: 2010/5/27 15:37
From mandurah
have you tryed grand auto wreckers they would probably have a ute there or would know were to get the mounts
hope this helps ,and the L20b stroker is pretty sexy !
Posted on: 2010/5/27 16:12
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From ACT
thanks mate I'll give em a call n see what they got.
Posted on: 2010/5/28 2:38
