« 1 ... 4 5 6 (7) 8 9 10 ... 22 »
Re: datski's 1200 sedan V1.2
From Perth WA AUS
If you didn't remove your roof lining it would be fine! Out of mind out of sight.
Posted on: 2010/5/28 7:16
Datsun 1200 2Dr sedan.
Yup. There are bits on my red B10 that I simply ignore. Where? What rust bubble?!
Get into it.
Posted on: 2010/5/28 7:19
From Albany, Perth Australia
the problem was is that it had some nice dents on the roof and in order to get there i had to take the lining out....gonna remake the roof lining while im at it. but oh well better finding out now then later. Not much left of the top of the rear windscreen. tis pretty bad....worse then i thought but oh well just means it will tack me longer
Posted on: 2010/5/28 8:03
1200 Smerf Mobile
From Perth WA AUS
Suppose I should remove my lining too.
Posted on: 2010/5/28 8:14
my rubber was original by the looks of it....was real hard and brittle, when i was taking the roof lining off so did the rubber....hence why i took both of them off anyway, but now that means i need more money to finish this thing
Posted on: 2010/5/28 8:20
1200 Smerf Mobile
From mandurah
hey brett i think i have a hood lining in the sedan ,ill have a look and if its any good its yours :)
Posted on: 2010/5/28 9:32
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
nah she'll be right....i am just gonna use mine as a template and make a new one
Posted on: 2010/5/28 10:17
1200 Smerf Mobile
From mandurah
ok but you now have a hood lining and you cant say no too a spare ,it will got with the sedan the sims if you dont take it !! please take it brett ,please !!
Posted on: 2010/5/28 10:27
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From mandurah
hey brett i was just looking through your pics and if you need the section out of the roof for the back ill pull the window out of the sedan and you can cut the rear section out when you come around
i need to dut this sedan up cos its goin to sims after i get the rust fixed on the coupe
Posted on: 2010/5/28 10:39
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Perth WA AUS
I'll cut it up for you, I love that!
Posted on: 2010/5/28 11:02
