A14 carby?
Quite a regular
From Byford
Hey all.
I am just down in bali and heard a rumour that you can but new datsun carbies here?
If so does anyone know where i can purchase one?
And also what brand they are?
cheers brandon
Posted on: 2010/5/28 9:18
Re: A14 carby?
From Perth WA AUS
PM Dundee1000 or weekend1000 they might be able to help.
Posted on: 2010/5/28 9:23
Datsun 1200 2Dr sedan.
Re: A14 carby?
From mandurah
ive got a good A12 carby that im willing to sell and all the A series carbys up to A14 are the same ,its of an 88 model ute and is running on the A12
and i heard you have some sunny or stanza steering stuff ,maybe a swap ?
Posted on: 2010/5/28 9:35
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: A14 carby?
I can buy brand new 1973-vintage carbies. Just keep watching eBay. They occasionally appear.
I fitted a 1980 A14 carb to may 1200 sedan. It runs good but runs a bit leaner than the original.
Posted on: 2010/5/29 4:51
Re: A14 carby?
im looking to buy a a12 carby
estyre how much for yours?
ddgonzal im guessing you look at ebay usa?
Posted on: 2010/5/29 15:54
Re: A14 carby?
look at all the eBay, set location to Worldwide.
Posted on: 2010/5/29 17:14
Re: A14 carby?
The carburettors are similar, but they are NOT the same.
Anti dieseling solinoid in some, but not others, different methods of mounting the air cleaner, auto choke in some, but not others, different throat sizes, different polution control vacuum fittings, different jet sizes & other minor changes to suit specific applications.
Pretty much all of them will fit all of the other engines but be aware that performance may not be as good as you expect unless the mixture is checked with an exhaust gas analyser on a dyno or road test & any corrections that might be needed are done.
I used an import engine's carb from an unknown A14 on my wife's improved performance 1200 engine. She loved the auto choke & I loved the peppy performance that the slightly larger throats permitted, but I had it checked with the meter before turning her loose with it.
Posted on: 2010/5/29 23:51
Love your Datsun.
Treat it well.
