Re: A12 Valve Seals
I went to my local engine head reconditoner/engine machinist and they had some in stock that fit - not sure off what car but I made a 12mm spigot with a 7.95mm parallel section and asked them to find a seal that fit.
I installed them and they work - no more oil burning at idle/revving then shutting throttle (high vac.) situations.
Carbs run a tad rich at idle and a tad lean at WOT (need a smaller pilot, drill main to No. 42 drill and raise needle 1 slot).
Just as I rolled into the driveway and went to turn the engine off the car just ran out of fuel...never trust a 1200 fuel gauge.
Posted on: 2010/5/31 11:45
Subject Poster Date
     A12 Valve Seals diymark 2010/5/22 1:20
       Re: A12 Valve Seals clyons8 2010/5/22 1:39
         Re: A12 Valve Seals diymark 2010/5/22 1:52
       Re: A12 Valve Seals ssskiwi 2010/5/22 2:11
         Re: A12 Valve Seals diymark 2010/5/22 2:22
       Re: A12 Valve Seals ddgonzal 2010/5/22 6:43
       Re: A12 Valve Seals diymark 2010/5/23 8:39
         Re: A12 Valve Seals clyons8 2010/5/23 10:37
           Re: A12 Valve Seals ddgonzal 2010/5/23 23:24
       Re: A12 Valve Seals diymark 2010/5/24 8:14
         Re: A12 Valve Seals ddgonzal 2010/5/24 8:16
       Re: A12 Valve Seals ssskiwi 2010/5/24 14:28
         Re: A12 Valve Seals ddgonzal 2010/5/25 1:35
       Re: A12 Valve Seals diymark 2010/5/26 8:47
       Re: A12 Valve Seals ddgonzal 2010/5/27 3:26
       Re: A12 Valve Seals diymark 2010/5/28 9:31
         Re: A12 Valve Seals clyons8 2010/5/28 9:34
       Re: A12 Valve Seals diymark 2010/5/28 23:56
       Re: A12 Valve Seals diymark 2010/5/29 0:12
         Re: A12 Valve Seals diymark 2010/5/29 0:42
           Re: A12 Valve Seals clyons8 2010/5/29 1:11
             Re: A12 Valve Seals diymark 2010/5/29 1:57
       Re: A12 Valve Seals coxsteve 2010/5/30 15:05
       Re: A12 Valve Seals diymark 2010/5/31 11:45
