Re: Finally! an engine setup i am sticking with permanently.
From Townsville, Qld
You could run an ignition only computer, they're out there in the market but not widely used.
Posted on: 2010/6/8 6:32
From Geelong, Vic
like jordan said, why would you bother. atleast if you want it NA just go quad throttle injection. all that effort would be much more worth while
Posted on: 2010/6/8 7:46
From Adelaide, SA
Im with Jordan, if you are going to spend all the time and money putting a CA in your datsun why not just leave turbo or NA efi, surely you would get alot more power, and it not going to be lighter without the efi stuff. sounds lot alot of work without an obvious reward.thats just my thoughts.
Posted on: 2010/6/8 7:50
From Rosewood, QLD
why are people talking to me on this thread i just gave the dude a link to the maddat CA18 crossmember page like he asked in his first post...
Posted on: 2010/6/8 8:09
1971 B110 sedan project.
2012 Nissan Micra daily.
From Midway City, California
it was meant as a joke, dont think too much of it. thanks for that link btw...
Posted on: 2010/6/8 16:27
if it was easy to restore, they would call it chevrolet
don't piss off America, or we will bring democracy to your country
From Taupo New Zealand
WAzz87 wrote:
get some huge cams ground up, use ca16de pistons for higher compression.
you'll end up with pretty low compression if you use CA16 pistons as they are 5mm smaller in diameter
I went down this track a few years ago, modified the inlet manifold to bolt the 45mm dellortos on and modified a distributor out of a ford telstar to go where the CAS normally goes. Did most of the hard work then changed direction. Still think it is a good idea though, might revisit it at some stage actually.
Why carbs over EFI? It justs suits some people better, probably cheaper for some people, and probably flows better than the factory EFI manifold so should go better!
Posted on: 2010/6/9 8:27
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
« 1 2 (3)
