Dodgeman whats with the name calling
I can now see in what you describe is that by supplying a boost signal to the bottom of the diaphragm it will keep the diaphragm at its maximum height in the pumps fuel chamber, by doing this you will garantee the pumps maximum flow and any backwards pressure on the fuel outlet will be cancelled by the supply to the bottom of the diaphragm.
At first I couldn't see this but after much thought it would work.
Also one other question you could probably better explain to me is - I don't see how the spring under the diaphragm would keep the fuel at a slightly higher pressure its job is to keep the diaphragm in a regulated position to regulate fuel flow
eg; on a naturaly aspirated engine when the engine is running at high speeds the carbies fuel bowl is constantly filling , so there will be hardly any resistance pressure ontop of the fuel pump diaphragm, this will make the spring push the diaphragm up height enough as much as it can till it reaches whatever resistance pressure is being placed ontop of the diaphragm, this will make fuel flow enough for these high engine speeds.
But at low engine speeds when the float in the carbies fuel bowl keeps the needle and seat closed longer there is a greater pressure above the fuel pump diaphragm. this pressure pushes the diaphragm and spring down but this pressure willnot totally over come the spring it will just place the diaphragm in a lower position, and this will make the pumps stroke be reduced this inturn reduceing the pumps flow in a situation when hi flow is not needed.
Otherwise the flow would over come the needle and seat.
This is why no return line is required when a mechanical fuel is used.
The only problem I can see is now on a boosted engine you will probably not have enough flow for the increased fuel requirements.
Also one other thing, if you were to seal the pump lever like you previously describe you would have much difficulty in actually haveing a pump that could be operated.
The only way I could see this problem overcome would be to run a pulley driven mechanical pump. but if you go to that much trouble you might aswell go electric.
Dodgeman you have got me thinking!
Cheers Steve.
