brake boosters for 1200 ute
From campbelltown (sydney) australia
hi all, im wondering what brake boosters will fit onto a 1200 ute, ive heard 120y or 180b one will fit straight on. im hoping the 180b will go on as i can pick one up for $66. thanks
Posted on: 2003/11/16 6:58
Re: brake boosters for 1200 ute
From Tas
I'm currently in the same boat as you. This seems to be a fairly grey area, but I'd like to get a decent booster - master cylinder setup going now while I've got the engine out for the rebuild.
I've been told every thing from 120y's, to a Sunny booster with a 180B mastercylinder.
Reward out to someone who can put us straight!
Posted on: 2003/11/27 7:06
From Perth W.A
120y if it will stop a ca18 it's gotta stop other stuff
Posted on: 2003/11/27 7:35
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
so u saying u know for sure the 120y booster will fit for sure?
and buff, if u find out anything send the info my way and visa-versa.
Posted on: 2003/11/27 11:35
From Perth W.A
i'm pretty sure, if you grab the booster and the master cylinder, you should be safe.
Posted on: 2003/11/27 11:38
120y Coupe
bloody hell that was quick, good on ya mate thanks for that.
Posted on: 2003/11/27 11:40
From Warwick, QLD
I use an La/LB Lancer booster and master, as long as you get the adapter part with teh booster it's a direct bolt on, it has great stopping power, although it's a fairly long booster but not that should really deter you from it.
Just a thought. Also Dattodude uses the same booster, he was the one who convinced me to use the lancer booster.
Cheers
Damo
Posted on: 2003/11/27 11:53
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Mackay
kegs. I'm only pretty new on the dato scene, but I put a pair of 80 model sunny struts (disk brake) and I feel there is no need to put a booster as it has a good feel in the brake pedal and I can lock up all 4 wheels in saying that I need to do something about the rear brakes as they are coming on a bit stronger than they should
Posted on: 2003/11/27 12:21
From Warwick, QLD
hey Wogboy do a search on rear brake bias as there was a dicussion using an early model Volvo I think it was rear brake bias controller. It might be a thing to check out
Cheers
Damo
Posted on: 2003/11/28 1:40
Team NEW SKOOL
From Canberra
Im using a 180B booster on my 1200 ute and it does a pretty good job. I have Verada discs with VS Commodore calipers up front and VP discs and calipers up the back.
I believe there was also a brake bias adjuster in the early (HQ?) Holdens. Shouldnt cost more than $20.
Posted on: 2003/11/28 9:52
www.valvebounce.com
motorsport and performance forum
