Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
ar su's good for turbo charging through
310
Posted on: 2003/11/27 22:36
i have two su's on my A14 and i want to know if they are good to turbo charge through. all suggestions are welcome
#2
Re: ar su's good for turbo charging through
89mm
Posted on: 2003/11/28 1:01
Have a good look at the Post about Supercharging (there is 5 pages and nearly 100 posts), which is pretty comprehensive in all respects with a good mixture of engineering theory and practical experience.
If you want an opinion and I stress it is only that, blow through systems have a potential for pressure sealing problems that are likely to be the source of continuing headaches. I reckon supercharging, either turbo or crankshaft driven coupled with EFI is the best bet by an order of magnitude.
#3
tens_and_twenties
Posted on: 2003/11/28 6:51
Nah, just put one of them SU's on the suction side of that turbo and be done with it
#4
Dragongoose
Posted on: 2003/11/28 15:36
you can use one but also you can two on the inlet of the turbo with a custom adapter and linkages, much easier to use one su though its much simpler and effective.
Cheers Allan
#5
Dodgeman
Posted on: 2003/11/28 15:55
Do you have two SU's on your engine, or do you have the factory "twin Hitachi" induction system. If it is the factory setup, then i suggest that you do not mess with it by robbing a carb from it. Leave it complete for later use or resale
If you are going to run a turbo with a suck through carb, then use a single, genuine SU carb of a size recomended by those who have run them. Multiple carbs on a turbo are not really a proposition. I agree with 89mm in all of his expressed opinions. Chris You can view topic.
