« 1 (2) 3 »
Re: Did the 1000's have seat belts?
Here is where you will find them
Posted on: 2010/6/18 3:10
From three hills alberta
mine is a 69 or a 70 and its had front and back seat belts. is that just a canadian option
Posted on: 2010/6/18 3:19
From Canada, B.C , Richmond
Yours have rear belts? What the heck?
Posted on: 2010/6/18 3:29
From Brisbane
:S thats not where i have holes ...
I have one on the side and one on the bottom, but its a lot farther back than yours ...
Hamza
Posted on: 2010/6/18 5:32
From Brisbane
And these 2 holes are threaded too ...
Posted on: 2010/6/18 5:33
From Freo
there should be holes for the lappy's at least in the front,
wreckers can't sell you seatbelts, it's against the law..
Coventries/repco sell aftermarket belts.. :)
Posted on: 2010/6/18 10:56
A15 PSI Project Motor
'72 CB750k,
So stand outside and wait for someone towing their old 1000 in. Buy them from the private individual before he junks the car. Keep it all Nissan.
Posted on: 2010/6/18 21:49
Seat belts are hard to find in good condition.
Even harder when they are to suit custom color interiors as the belts are intended to match the coloured upholstery(?) red seats, red belts, blue seats, blue belts, black black.
You'd be hard pressed finding a black set of seat belts, which would be the fairest match to your interior.
I have some blue seat belts knocking around the place but they'd look out of place with your interior, so then that moves us to the next question! Looks before safety? I suppose you could dye them somehow to black, that wouldn't look too bad.
Otherwise you may want to ask an upholsterer?
As for the rear seat the bolts holes for the seat-belts are located behind the seat in the boot compartment but before the fuel tank. Two either side of the rounded ridge in the centre (which crossover to attach to their corresponding latch) and one either side of the vehicle (obviously on the inside).
Not sure what those holes are in the floor, I'd have to have a look again, to see where exactly they are, little confused by the photo.
Posted on: 2010/6/18 23:20
Edited by clyons8 on 2010/6/18 23:43:52
Edited by clyons8 on 2010/6/18 23:44:43
From Brisbane
Safety does come before looks, but i can have both ... I may need to get some custom made to suit colour and length ...
I should have mentioned this earlier, but that pic is of the drivers side ...
The only prob im having is the placement of the belts ... The hole on the right hand side of that pic is pretty much in line with the bolt on the pillar above, so im sure that ones all good, but the other is very far back ... I've had a look 3 times and cant find anything else on either side ... Maybe they were cut out and filled when the car was redone?
Posted on: 2010/6/19 2:27
From Brisbane
lol, I may be waiting a while ...
Posted on: 2010/6/19 2:29
« 1 (2) 3 »
