Tuning procedure of A15
Hi friends, what is the procedure of tuning A15 Nissan Vanette engine? (carb model. 1500cc)contact point distance, valve clearance, angle etc. thanks
Posted on: 2010/6/20 6:50
Re: Tuning procedure of A15
From Toowoomba
Do a search for DatsunSunnyB310WSManual.pdf
I'm sure there's a link in the forums somewhere...:)
Posted on: 2010/6/20 11:43
It is the same as A14 and A12. It varies a little bit by country and year.
The following settings work well: http://datsun1200.com/modules/mediawiki/index.php?title=Tune-up
Posted on: 2010/6/20 19:29
Thank you friends, I found a pdf from this site it is very usefull I will try to add the link. actualy this van is used Japanees 89 model.
Posted on: 2010/6/21 8:03
Japan-market 1989 A-series engine should have electronic ignition, so no points to worry about.
Posted on: 2010/6/21 19:02
Unforchunatly I havea carb model and it is 89 year made in japan.
Posted on: 2010/6/22 5:57
Yes, the 1989 Datsun 1200 with carburetor was the first to have electronic ignition.
Posted on: 2010/6/22 6:36
Actualy I downloaded DatsunSunnyB310WSManual.pdf I guss this would be alright. I tuned the engine today ignition and valve clearance no tapping sound only feel a little miss in slow idler. attached picture is Nissan Vanette c22 A15 engine cover open.
jpg  IMG_1240.JPG (179.20 KB)
13303_4c23671c65edb.jpg 627X470 px
Posted on: 2010/6/22 13:03
Edited by heratha15 on 2010/6/24 14:56:22
Edited by heratha15 on 2010/6/24 15:04:38
Edited by heratha15 on 2010/6/24 15:09:53
