« 1 (2)
Re: cant get my oil filter off!!!
From Snohomish, WA USA
Yes, as DD has stated, Never use a tool to tighten the filter. Only use one to take it off. When installing, you will get more than enough seal with your hands unless you lack any strength, then a quarter turn with the tool will be required. Thin layer of oil on the seal as well.
When removing with the tool, grip as close to the block as possible to avoid crushing the filter.
Posted on: 2010/6/20 17:14
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
« 1 (2)
