Re: castor explained..... please
From Sydney
ROConnor wrote:
Benny, Have seen moded control arms with rod ends to eliminate the bushing problem. I went and bought some bits to do this, but as you know have given up on the 1200 for now.
Good point, but wasn't sure if you can use them on a streeter....
Posted on: 2010/6/24 9:17
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
A very small %of the gains is (caster and its effects on camber of the outside wheel in a turn are obviously the 'big' factor) actually from relocating the front wheel centreline forward just a touch, which is not quite as good as but similar to moving some weight rearward, and getting a more advantageous polar moment of inertia (very basically the closer most of the weight is to the centre of gravity the quicker the car can turn in. If on the other hand you put just 10-20 kg of weight on a specially made bracket so that it sits say 1-2metres forward of the front axle centre line, it'd have great 'leverage' o the car and make it want to slide wide/understeer more significantly. Obviously nobody is suggesting really rigging up such a thing, but it's a good way to visualise why shifting (some, and of course it's all relative to a specific car) weight back a little, or moving the front wheels forward just a little bit can actually have some positive effects.
Short version of all that, if you can manage it, increase the caster by moving the bottom of the strut forward. If you can't the caster itself is the majority of the gains, so do it however you can manage it, you only miss out on a few % of the total gains.
Posted on: 2010/6/24 15:10
John McKenzie
From Geelong, Vic
benny, pretty sure any modifications to the suspention components is pretty illegal...that said i ran rod ends on my control arms so that they could pivot where ever they wanted
going to change back to bushes as the rod ends wear out pretty quick with no covers over them
Posted on: 2010/6/24 22:54
what would the castor be on an unmodified 1200 front end?
The castor setting is non-adjustable on the 1200 and on many other McPherson strut cars.
This doesn't mean that you cannot change the castor. You can, by cutting the tension rod bushing and tightening it up again. Or by re-threading the tension rod so it can be shortened up.
After doing this, the aligment must be re-checked (that is, the toe-out setting).
Castor is what the trolley cart at the market has: The angle of the wheel hub, so that the wheel tracks straight when the cart is pushed ahead. Datsun 1200 has minimal castor for a light steering action. But it is too light and does not track well at highway speed. More castor than stock is better. 2-3 degrees has been recommended. 4 degrees is the most I've ever heard of for a 1200.
Posted on: 2010/6/24 23:18
The stock castor spec is: 20' to 1°50' for Sedan & Coupe
The Van specification is better: Caster: 1°05' to 2°05'
This explains why some 1200s track better than others... at 20' there is almost no caster yet it is considered "in specification".
Posted on: 2010/6/25 2:50
From Sydney
Ange, here is a pic of the front end of my sedan as described in thread on page 1.
Posted on: 2010/6/26 11:44
1970 KB10 Coupe
S13 caliper b...
nice bump steer spacers, where are they from? do they suit stanza struts?
Posted on: 2010/6/26 15:31
From Sydney
They are from B-Pro and are specific to the bolt spacing of the B110 struts [barrower bolt spacing compare to stanza]
From memory Datsport do some nice spacers for the larger struts...
Posted on: 2010/6/27 0:16
1970 KB10 Coupe
S13 caliper b...
From Christchurch NZ
It's quite common here tosee rose jointed bottom arms on race/rally 1200's. The problem that can be found though is as you pull the lca forwards, the castor rod angle alters, and becomes different to the angle of the bush pocket on the front of the chassis.
One bloke I met reckoned he used to use rack ends to correct that angle.
Posted on: 2010/6/27 1:43
Forced Induction!
From Florida, USA
I had solid bushing on the inner of the lca and that made getting a bunch of castor a chore. Ultimately had to cut the bushin in half so that the front and rear of the bushing could rotate a bit. Also drilled out the "inside" of the bushing so that the bolt didn't have to line up perfectly except at theouter edgeof the bushing. Lots of grease. Car handled well.
Posted on: 2010/6/27 3:35
Carbon offset purchases are the Environmentalist equivalent of Television Evangelists being caught with Hookers.
« 1 (2) 3 »
