yeah did i bit of testing of the kill rust...matt black kill rust dries fine over the seam sealer, seems that its only the green that really has a problem with it
D, yes i could use a later H190 housing, but then i'd need to find different axles that are long enough to be shortened or short enough to not need it. bluebird ones are not long enough to be shortened to the right length
cant say i'll be getting a bake room for the enamel to set worst case is i just paint it again at a later stage. but then its not paint you will see so i dont really care that much
rightio, actual update. spent a good 10 hours on the car yesterday bogging the rear quarters and stuff. was in too much of a rush to remember to take a pic of the bog before it got painted. so these will have to do, paint is rather thin on the inside but i figure that it doesnt need that much etch on the inside as there was paint there to start with
also found out why enamel and acrylic dont like each over when i etched over some killrust that was on the end of the sill...nice paint stripper effect
quarters didnt come up to bad, still gotta smooth the bottom of the drivers side and fix up a couple of other small spots ive noticed but it wasnt really too bad for the care factor i had at the end of the day
going out to drill some holes in the roof so that its ready to be welded on as ive given up on trying to find a spot welder
and hopefully might have the engine bay primed over the weekend and the bog finished off
