#11 Re: Car doesn’t pull as usual
Sumith Posted on: 2010/6/29 4:23
Hi Guys
I checked the spark Last night actually it is good i get bright blue spark from all plug wires.
thanks
Regards
sumith
#12 Re: Car doesn’t pull as usual
Sumith Posted on: 2010/6/29 5:24
Hi Guys
Just Checked my Ignition coil
It has got these rating
+ and - of coils resistance is 2.6 Ohms
either + or negative with High end side 11080 Ohms
According to wiki specs this is out
* Primary (12V) Resistance @ 20C/68F temperature: 1.17 to 1.43 ohms
Secondary (high voltage) Resistance @ 20C/68F temperature: 11,200 to 16,800 ohms
what do you think guys ?
thanks
Regards
sumith
#13 Re: Car doesn’t pull as usual
ssskiwi Posted on: 2010/6/29 5:49
Have you pulled the plugs again? If #2 is wet again then it is specific to that cylinder and won't be the coil. A wet plug indicates no spark on that cylinder.
One cylinder only is indicative of a problem after the coil i.e. dizzy (points, rotor, cap, leads), plugs, valve adjustment etc.
Give it a tune up, check plugs and plug gaps, check ignition lead resistances (the longer they are the more resistance), check leads are firmly inserted into cap, etc...
#14 Re: Car doesn’t pull as usual
Sumith Posted on: 2010/6/29 6:25
Hi ssskiwi
Actually i didn't pull the spark plug yesterday,ill pull those today and let u know
Thanks
Regards
sumith
#15 Re: Car doesn’t pull as usual
Sumith Posted on: 2010/6/30 6:30
Hi Guys
yesterday checked 2 spark plug those were thick black and smelling fuel,but not wet ,cylinder 2 was bit wet
thanks
Regards
sumith
« 1 (2)
