#11 Re: Custom made Vintagespeedster manifolds for 1000 / 1200
clyons8 Posted on: 2010/6/29 16:03
Come on D, you can do it!!
#12 Re: Custom made Vintagespeedster manifolds for 1000 / 1200
heathbruce Posted on: 2010/6/30 0:40
great pickup D,
make sure you show your progress.
Where did you find them and what are they off?
cheers
Bruce
#13 Re: Custom made Vintagespeedster manifolds for 1000 / 1200
D Posted on: 2010/6/30 2:11
All Nissan by Aisin from the Nissan Super March turbo, a supercharged and turbo
ma10 all alloy ma10 engine with hemi heads and crossflow ohc layout.
This is the benchmark to this technology 20 years ahead of the current VW golf.
SUS are off a Triumph 2.5 litre six so halve that and 1.25 is almost right on.
Now gotta get the stepped pulleys for the crank, water pump and front and rear ones
made for a Hilux diesel alternator which runs a shaft at the back to for the air
pump which will power the SC. Im thinking of using timing sprockets from ohc and
dohc engines, although a little heavy theyre easier to find than twin pulleys.
This is the easiest way, as the back of the alternator will balanced the force on
the bearing at the front from the crank and the rear via the SC.
Also the Alternator already run 2.5 or 3:1 faster than the crank so will suit my
aim for 10psi boost with a 2:1 ratio at the rear.
6000rpm limit will see the SC near 12000rpm very rarely and mostly only 4000 so
halve of the 16,000 redline of the SC.
#14 Re: Custom made Vintagespeedster manifolds for 1000 / 1200
Wurzel Posted on: 2010/6/30 10:01
I see what you did there Chris, and concur ;)
Also: wrapped headers can be sexy too:
#15 Re: Custom made Vintagespeedster manifolds for 1000 / 1200
ssskiwi Posted on: 2010/6/30 10:10
D, just a thought with the diesel alternator. What is the max RPM the Toyota diesel spins to? You could be adding 50-60%+ onto the operating RPM of the alternator and I was worrying if it could come apart with the high (for a diesel) RPM?
#16 Re: Custom made Vintagespeedster manifolds for 1000 / 1200
D Posted on: 2010/7/1 2:37
Didnt see the link :0)
The hilux diesel alternators pulley is 2.5:1 smaller than engine crank or higher
last time I calculated so say 2.5 x 4800 max rpm = 12000rpm
If I use the latest AC style Mercedes diesel alternators by bosch Id be set as
they are the most efficient, but although I had several in my hand from test model
Musso 4x4 that never passed and where scrapped, I didnt bother then :(
The original A10 alternator pulley is about 2.5 to 3 times smaller than the crank also.
#17 Re: Custom made Vintagespeedster manifolds for 1000 / 1200
D Posted on: 2010/7/2 12:38
Todays I ducked out and found a very rare diesel Jap import.
1989 Mazda capella pressure wave charged engine. Some kind of
supercharger called a comprex pressure charger.
All a heavy cast iron contraption but the alloy head diesel
engine was impressive with 495,000klm.
heres a pic for reference of the alt and sc, funny they weigh the exactly the same.
jpg  altwithsc.JPG (192.11 KB)
737_4c2dd51d64b2f.jpg 785X471 px
#18 Re: Custom made Vintagespeedster manifolds for 1000 / 1200
clyons8 Posted on: 2010/7/2 12:41
A turblower? That's really interesting stuff, never seen anything like it.
#19 Re: Custom made Vintagespeedster manifolds for 1000 / 1200
D Posted on: 2010/7/2 13:12
yeah but its more complex than I thought when researching it.
On my setup just to clear things up a little, my blower will be attached
to a custom sidedraft manifold at 15 or 20 degrees and the pulley will be
inline with the rear pulley on the alternator below it.
So I really need a vanette exhaust manifold or a custom unit that allows
clearance for the belt.
The pulleys are going to be stepped ones but maybe the Alternator front,
crank and waterpump will have to at minimum be twin pulley V ones.
« 1 (2)
