a14 with a turbo or a15 without
Quite a regular
From brisbane qld
i just want to no what would be better and faster
Posted on: 2010/6/30 9:01
Re: a14 with a turbo or a15 without
From Sydney
Depends on the intended use... Capacity and/or a turbo alone wont make one engine outright better than the other.
At the end of the day its comes down to the $$$ investment and selecting the right parts. Either option can be made to haul.
Posted on: 2010/6/30 9:52
Edited by benny on 2010/6/30 11:09:24
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Quite a regular
From brisbane qld
well iv got an a15 at the moment and mate is buliding an a14 with a turbo but as i am a p plater i cant turbo it and im wondering what i can do to make mine quicker that his its a standed a14 with a turbo
Posted on: 2010/6/30 10:14
From Ringwood, Melbourne, AUS
I think you will need to do quite a bit of work to a std A15 to match the A14T. 100CC isn't that much extra HP compared to what a turbo could add.
Posted on: 2010/6/30 10:41
Deano
Quite a regular
From brisbane qld
what could i do i have 5 grand sitting thier but im not sure what to do
Posted on: 2010/6/30 11:08
Depends on what you have access to - I'm a fitter so just about anything is possible (well... how much time do I want to spend on it is the question here) but I'm not sure what you have access to.
This is what makes the cost vary heaps - how much work you want to do/can do your self.
Common NA mods involve...
Cams - more duration, lumpier profile.
Porting - clean up and open up bowl/guide area, port matching
Heads - find your self a A14/A15 oval port if you dont already have one
Exhaust - headers (or even stock manifold) with a 2" system
Intake - goes hand in hand with carbs
Carbs - Webbers, SU's or to be different; motor bike carbs (looks best!)
Pistons - Hi comp (forged if you have money to burn)
Crank - Polish and knife edge
Rods - Polish and lighten
Flywheel - Lighten plus drill
Springs - higher shut pressure on the valves
Retainers - Ali or titanium valve retainers
Push rods - lighter ones
Crank Pulley - lighten, smaller for less fan rpms
Rebuild - rings, seals, bearings, oil pump, water pump, ARP bolts
Roller rockers - only really good if you have cut valve guides or tons of money for bling and requires the mandatory perspex rocker cover!
Sump - baffles + larger
Balance Engine - blue print rods too
Bigger Radiator
Electric Dissy
Last but not least a TUNE! Get the carbs running smick and set your timing (to what fuel you want to use) or all that work is wasted.
I think Ive covered all the mods beside silly things like making custom cylinder heads or full race mods like larger valves, etc.
Posted on: 2010/6/30 11:45
Talk to bige on the forum here, he seems to have a good reputation for making these A series hum.
Posted on: 2010/6/30 11:48
Deano
From SA
im making a series turbo manifolds if your interested mate?
http://datsun1200.com/modules/newbb/v ... hp?topic_id=44398&forum=1
heres the link
cheers
Dan
Posted on: 2010/6/30 11:51
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
