Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Best head for porting/modifying?
ssskiwi
Posted on: 2010/7/2 12:27
What is the best head for modifying/porting?
Is there more meat (smaller coolant jackets?) in a round port or do you start with an oval port as the ports are already larger? Do you carve up a "rare" GX head over a H89 over a round port? I am looking to get a head fairly seriously tampered with in the future and if it can be done with a dirt cheap head rather than paying through the nose for a "performance" head like a GX or H89, then I would rather do that.
#2
Re: Best head for porting/modifying?
bige
Posted on: 2010/7/2 12:42
go to project build page 3 i thick ***heads (painful veiwing) Topic has Attachments [1][2][3] things i've done over 25 years.cheers
#4
ssskiwi
Posted on: 2010/7/2 13:16
I have looked at your work there bige but I have no idea from that carnage which is the better base to start from..
![]() There has been some fairly serious sectioning happen there in the name of R&D..
#5
bige
Posted on: 2010/7/2 13:25
all i can say is good luck, don't assume all same number casting are the same in ports.(every head is different). your opening a can of worms. cheers
#6
ssskiwi
Posted on: 2010/7/2 13:47
Yeah I guess so, that's why I intend to get someone who knows what they are doing to do the work.
Just want to get the best base to start off so I don't get a "sorry mate, this head is sh1thouse, you should of really got xxx head" after I have spent $$$ (or more likely $$$$ ) on wasted porting work..I realise with core shift etc that even the "same" heads are different internally but if I can get the "best" base i.e. smallest coolant cavities, most meat in port walls to start from, I am more likely to get a good result.
#7
levey
Posted on: 2010/7/2 14:00
Contact SW motorsport and ask about a JTS head, they should be able to help.
http://www.swmotorsport.com.au/index. ... 108.html&lmd=39067.093299
#8
clyons8
Posted on: 2010/7/2 14:16
He's asking what is the best candidate to begin modifying in terms of suitability in material/structural composition and costs.
Levey, your Jeff Taylor head (Andy's old one) was a modified H89 no? Dean's asking about a budget start I think not a big buck special from Jeff Taylor (although I should say he's really well priced and has a good reputation as a knowledgeable A-Series builder).
#9
bige
Posted on: 2010/7/2 14:44
MAYBE ONE OF THESE I HAVE WILL WORK
A NICE GX VIRGIN AND THE ANSWER IS 'NO' Attach file: PIC_0316a.JPG (73.88 KB)![]() PIC_0304a.JPG (73.68 KB)![]() PIC_0314a.JPG (73.74 KB)![]() PIC_0297a.JPG (86.18 KB)![]()
#10
clyons8
Posted on: 2010/7/2 14:55
Wow, there's a bitta bling! Nice. I thought that was the later Nissan Comp head for a second there! You filled the manifold coolant galleys nicely.
