« 1 ... 10 11 12 (13)
Re: WINTON SPRINTS July 4th Who`s in?!!
From Sydney,NSW
Yep, 296mm discs here, 32mm thick. I have heard of guys using verada 296mm discs, thinner and lighter.
My discs are quite heavy, they dont even change color after being flogged though.. and pedal is there every time!!
I'll try and get a shot soon.
Posted on: 2010/7/7 0:40
From Las Vegas USA
I have the same thing with the 280ZX calipers and discs on my coupe.................I'm a steer with the pedals driver and often have the brake on the gas on at the same time and the brakes never fade............but man the stock 280ZX is heavy.
Choole, one other question what spec / state of tune is you're motor in and which engine? A12-14-15 etc.
Tom
Posted on: 2010/7/7 1:21
From Sydney
Yes you are right, my mistake.. Should have read it better the first time..
Mine are R32 280mm rotors
Posted on: 2010/7/7 3:15
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Sydney,NSW
Completly stock Sr20de, wrecker motor. Standard computer and airflow meter, just extractors.
Not for long though...
Where abouts do you run your car benny?
Posted on: 2010/7/7 6:51
From Sydney
Unfortunately, not since my son was born, he turns 5 this year. Hopefully I can make a return and give the old bus a spin on the track. Car will have new rear end, new geometery and powerplant.
Posted on: 2010/7/7 7:55
1970 KB10 Coupe
S13 caliper b...
