D wrote:
Im thinking whether the coupe engine with its 66-67hp might go with Scharger?
Maybe too much overlap? would be nice to know the specs of the kb10 camshaft
to see if its a good grind or not. Need something with a 114 degree lobe separation.
Might have to use a stock b10 camshaft otherwise.
I don't remember the source but I seem to recall that the A10 cam had a few thou more lift than a 1200 cam, but that's all that there was in it, a few thou.
All A10 engines use the same cam, so a coupe one won't offer any advantage.
Remember that these single carb cams are designed for 'relatively' low engine speeds to allow little old ladies to tootle around high density urban areas at low speeds, so a stock A10 or 1200 cam should be fine in a blown engine, at least untill you get the bugs sorted.
EDIT
OK, OK, here's the goods on cam timing from my factory go-fast manual.
ONE CARB, Std CAM. Part No. 13001 - H1000 [stock 1200 cam]
Working angle. 248 degrees.
Intake opens 14 deg. BTDC
Intake closes 54 deg. ABDC
Exhaust opens 56 deg. BBDC
Exhaust closes 12 deg. ATDC
Overlap 26 deg.
Valve lift 8mm
Valve clearance when checking 0.35mm
[remember these figures are measured at the valve]
Lobe separation is not mentioned but you should be able to figure out what it is if you do some maths. It's late & I'm too tired
I also have details for the GX cam as well as three factory optional race cams if required.
I hope that this is of some help.
