Re: Blow/Draw Through
Yeah it sounds complex but all there is, is a handful of parts. There wont even be any semiconductors, I can get buy with 2 or 3 relays.
I just dont like efi - to much "crap"; MAP, IAT, O2 sensors, ECU's, injectors, IAC valve, surge tank, fuel pump and the list goes on.
Then theres the fun of tuning it.
In my draw through setup there will be a single 50mm flat slide motorbike carb which tuning would be a dream (I personally find tuning motorbike carbs just easy) - in one afternoon I could get it running 90% then connect my wide band O2 to check the a/f and see if there's any room for improvement.
My injection nozzle will be on the turbo output side facing down the piping - the log style manifold and the bend or 2 needed to pipe the turbo to the engine will allow plenty of time for good mixing. I'm trying not to inject before the turbo as the water droplets will erode the turbine.
Posted on: 2010/7/8 4:16
Subject Poster Date
     Blow/Draw Through diymark 2010/7/7 3:11
       Re: Blow/Draw Through diymark 2010/7/7 8:16
       Re: Blow/Draw Through A14force 2010/7/7 9:30
         Re: Blow/Draw Through 1200rallycar 2010/7/7 9:59
           Re: Blow/Draw Through diymark 2010/7/7 10:21
       Re: Blow/Draw Through elemental_funk 2010/7/7 13:50
         Re: Blow/Draw Through D 2010/7/7 15:29
       Re: Blow/Draw Through diymark 2010/7/7 23:44
         Re: Blow/Draw Through D 2010/7/8 1:58
       Re: Blow/Draw Through diymark 2010/7/8 4:16
         Re: Blow/Draw Through D 2010/7/8 6:41
       Re: Blow/Draw Through diymark 2010/7/8 8:42
         Re: Blow/Draw Through D 2010/7/8 11:25
       Re: Blow/Draw Through DatsAndy 2010/7/8 11:43
       Re: Blow/Draw Through D 2010/7/8 13:40
       Re: Blow/Draw Through diymark 2010/7/8 23:27
         Re: Blow/Draw Through D 2010/7/9 0:02
           Re: Blow/Draw Through thedevilshands 2010/7/9 0:34
       Re: Blow/Draw Through diymark 2010/7/9 0:41
         Re: Blow/Draw Through diymark 2010/7/9 0:49
           Re: Blow/Draw Through Kiri1 2010/7/9 10:24
         Re: Blow/Draw Through thedevilshands 2010/7/9 1:11
       Re: Blow/Draw Through diymark 2010/7/9 1:59
       Re: Blow/Draw Through thedevilshands 2010/7/9 3:15
       Re: Blow/Draw Through diymark 2010/7/9 4:21
       Re: Blow/Draw Through thedevilshands 2010/7/9 4:36
         Re: Blow/Draw Through thedevilshands 2010/7/9 5:32
       Re: Blow/Draw Through diymark 2010/7/9 5:02
       Re: Blow/Draw Through D 2010/7/9 10:18
       Re: Blow/Draw Through diymark 2010/7/9 10:56
       Re: Blow/Draw Through jmac 2010/7/9 11:14
       Re: Blow/Draw Through A14force 2010/7/9 22:30
       Re: Blow/Draw Through datsa73 2010/7/10 1:24
       Re: Blow/Draw Through thedevilshands 2010/7/10 8:44
       Re: Blow/Draw Through diymark 2010/7/10 9:41
         Re: Blow/Draw Through D 2010/7/10 10:27
       Re: Blow/Draw Through jmac 2010/7/10 10:17
       Re: Blow/Draw Through diymark 2010/7/10 11:47
         Re: Blow/Draw Through D 2010/7/10 12:13
       Re: Blow/Draw Through jmac 2010/7/11 11:23
       Re: Blow/Draw Through bakat 2010/7/11 11:25
       Re: Blow/Draw Through estyre 2010/7/11 16:54
       Re: Blow/Draw Through diymark 2010/7/11 22:42
         Re: Blow/Draw Through D 2010/7/12 0:04
       Re: Blow/Draw Through jmac 2010/7/12 6:59
         Re: Blow/Draw Through estyre 2010/7/12 9:22
           Re: Blow/Draw Through Dundee1000 2010/7/12 10:14
       Re: Blow/Draw Through jmac 2010/7/12 17:44
         Re: Blow/Draw Through D 2010/7/13 0:46
       Re: Blow/Draw Through jmac 2010/7/13 9:53
       Re: Blow/Draw Through D 2010/7/15 10:32
       Re: Blow/Draw Through sikyne 2010/7/15 11:18
       Re: Blow/Draw Through diymark 2010/7/19 3:34
         Re: Blow/Draw Through D 2010/7/19 3:47
       Re: Blow/Draw Through diymark 2010/7/19 9:43
         Re: Blow/Draw Through D 2010/7/19 10:24
       Re: Blow/Draw Through diymark 2010/7/19 11:49
       Re: Blow/Draw Through supafatto 2010/7/19 12:06
       Re: Blow/Draw Through jmac 2010/7/19 14:28
       Re: Blow/Draw Through diymark 2010/7/20 7:59
       Re: Blow/Draw Through supafatto 2010/7/20 8:24
       Re: Blow/Draw Through diymark 2010/7/20 8:51
         Re: Blow/Draw Through diymark 2010/7/20 11:45
           Re: Blow/Draw Through supafatto 2010/7/20 12:20
       Re: Blow/Draw Through estyre 2010/7/20 10:23
