« 1 (2)
Re: 78BW or H190 which is stronger ?
From Sydney, Australia
I ran a CA18de and stock CA18det for 5 years on a H165 without blowing up the diff.
For drifting.. better to get a h190 or bw78. I love the idea of cheap parts (unlimited supply) when using the BW78.
Use what's cheap first.. if it's not a daily driver this is a good idea. If you can't afford time off to fix busted diffs, then put something stronger in before you start thrashing it.
Posted on: 2010/7/8 6:56
From mandurah
i have the motor in a 1200 coupe and i have a couple of spare 120y diffs
i have a skyline diff ready to be shortened and i need to know if im better of just going for the 190 ,but i like the idea of disks from standard on the r31 diff
do the h190s bolt straight in ? or will i need to relocate the mounts?
Posted on: 2010/7/8 7:05
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Pretoria SA
Hi, check out Tech Wiki related to H190 spec, alot of info you might find usefull.
Posted on: 2010/7/8 7:34
« 1 (2)
