Re: My Sunny
Ok I had look and I saw what looked like a removable panel for the plug - wasn't sure so I removed the fan and felt behind and there were a couple resistor coils (one loose) and I knew that must have been it. I pulled it out and yep - one bolt+nut fell off and left connection free.
I put a new bolt with a lock nut on and it works!
Makes you wonder though - why crimp two of the connections and then bolt the third on on?
Also, the water temp sensor wire is in another harness so I wound back that emissions harness (wasn't actually connected to anything) and cable tied it behind the wiper motor - looks neater now. So once again thanks for the pointers.
Just gotta machine up a blanking plug for that unused sensor (it was used but the wires broke off so I faced it off in a lathe to clean it up.)
Posted on: 2010/7/16 1:18
Subject Poster Date
     My Sunny diymark 2010/7/15 2:47
       Re: My Sunny benny 2010/7/15 3:05
       Re: My Sunny diymark 2010/7/15 3:07
         Re: My Sunny sunny1046 2010/7/15 3:25
       Re: My Sunny diymark 2010/7/15 3:28
       Re: My Sunny b310gx 2010/7/15 11:17
       Re: My Sunny diymark 2010/7/15 23:47
       Re: My Sunny diymark 2010/7/16 1:18
       Re: My Sunny b310gx 2010/7/16 10:32
       Re: My Sunny diymark 2010/7/17 1:12
       Re: My Sunny Rallytwit 2010/7/19 1:23
