Wheel nut size for TRX rims.
From Brisbane, Australia
Hi, picked up some Bluebird/TRX mags, just wondering what size/style nuts I need to get to fit them?
Thanks
Geoff
Posted on: 2010/7/16 8:32
Re: Wheel nut size for TRX rims.
they are hard to find but u can buy them new from nissan if you ask for et turbo nuts but they r black
or goto a custom nut maker theyll have to make them if u cant find some
they have a shank then a taper
Posted on: 2010/7/16 10:19
Car free
From illawarra, nsw australia
i got some good ones from super cheap auto
a bit heavy on the wallet but they suit the trx wheels just fine
Posted on: 2010/7/16 13:26
datsunless. for now
From Sydney
What i did with mine was i used mag wheel nuts with a shank which suited the hole in the trx wheels. the nut set came with washers. I then grinded down the outside diameter of the washers and knocked them into the rim where the taper is (2 washers per hole)Sounds rough but it worked well and it didnt break the bank.
Posted on: 2010/7/16 13:57
From Sydney, Australia
Posted on: 2010/7/16 22:26
B110 sedan
I might have a set in the shed. I'll have a look later. I paid $50 for them a few years ago as they are pretty hard to find. Then I didn't use them...Go figure.
Posted on: 2010/7/17 0:21
