« 1 (2)
Re: Crankcase Ventilation and Rocker Cover Breather Lines
From Perth WA AUS
Sounds like you grabbed my wallet!
Posted on: 2010/7/16 13:36
Datsun 1200 2Dr sedan.
From mandurah
i thought all A series motors blow smoke haha ,i noticed that when i started my A12 on the ground with no rocker cover or crankcase ventalation hooked up it tended to get abit smokey
could it also be the oil might need changing aswell as the pcv valve being installed ?
Posted on: 2010/7/16 13:43
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From sydney.nsw
chris, some hints i found that may help you(refer to page 1) haha cheers hope they help.
Posted on: 2010/7/16 17:10
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Haha, love your approach to the engine rebuild.
How much would you charge for a rebuild around about bige? or what would a re-build kit cost from you without the pistons (which are 1.5mm oversize by the way).
Posted on: 2010/7/17 0:52
From sydney.nsw
give me a list of bits u need and sizes eg/ rings/bearings/gaskets/timing chain kit/ cam ,lifters/etc ,what engine is it, cheers
Posted on: 2010/7/17 1:32
From Townsville, Qld
not that it's related in anyway to this but the other night my oil cap blew off the car and I ran over it! I went to check the catch can cos it's got an "atmospheric release mesh device" on the top of it and the tubing to it was harder than usual.
might have to sort that out right now in fact before I go anywhere
Posted on: 2010/7/17 7:04
« 1 (2)
