« 1 (2)
Re: A12/A14/A15 Ajustable cam pully/ Vernier pully
From sydney.nsw
not sure , but are u thinking it changes timing as u go, this is a set once and lock up type set up, it does not vary timing as the engine runs.hope this help. cheers ernie
Posted on: 2010/7/20 6:58
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Pretoria SA
Ernie, no im not gonna fiddle with it, ones its diled it remains, but its uncharted waters for me, if i make the setup right the first time round, diling tuning even replacing the cam is just so much simpler..
And it looks lekke anyway...
Posted on: 2010/7/20 7:06
1400 Turbo
From sydney.nsw
if your playing with different cams, it helps (but not really needed.but thats opinion), cheers.
Posted on: 2010/7/20 7:48
From Christchurch NZ
There is a cheaper way of altering your cam timing. Turn your cam sprocket around half a turn, and then dial in your cam using a degree wheel and DTI.
Once your timing is where it needs to be, drill a new dowel hole in the end of you camshaft, and tap the cam dowel back into the new hole. It's not adjustable, (Although I did once do a multi hole adjustable cam sprocket, but the engine died a horrible death before I got the chance to tinker with the timing.
Posted on: 2010/7/20 9:40
Forced Induction!
From Pretoria SA
A14force, i understand what you mean, but i just dont have the knowledge to atemt this, i do how ever have a bud with his own dino and he has a bigger IQ than me, So was thinking ill make a sprocket, get the car running and go visit my bud, then i make the ajusting his baby
Posted on: 2010/7/21 7:24
1400 Turbo
Not too shy to talk
From Boksburg
Kiri1 please let us know your results after the dyna testing. Maybe i'll go that route one day.
Posted on: 2010/7/21 9:38
From South Africa
I have an old Tomei TS timing pulley, works a charm, using a timing pulley on a mild motor isn’t worth it, on a worked motor sure,,, but, when you’ve worked it enough your almost setting it up just so your valves don’t touch the pistons more so than trying to make more power
Ohh and for "gays, enjins, diling" etc MS word spell checker works a treat
Posted on: 2010/7/21 19:31
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
From Pretoria SA
Hi Rezlo, Can you remember where you bought the gear and what you payed for it.
Has anyone put this on a Turbo?????????
Posted on: 2010/7/23 6:26
1400 Turbo
From South Africa
I got it on one of my oversea's trips, was about R3000 if i remember right
Posted on: 2010/7/23 14:21
'07 Hilux - Tow car
« 1 (2)
