« 1 ... 3 4 5 (6) 7 8 9 »
Re: old_school's CA Coupe
From Mandurah, Western Australia
Got a spare 1/2 hour after work today, so started cutting all the un-neccisary mountings off the diff. Will post up more pix as I go.
jpg  diffr312.JPG (26.54 KB)
2484_4c445e1734108.jpg 448X336 px
Posted on: 2010/7/19 15:16
From Trinidad and Tobago, West Indies
love the coupe and work done
what front stabilizer are you using??
and what custom sway bar? can i see photos? i have a CA too and would like some ideas
Posted on: 2010/7/21 5:56
My Datsun 1200 blog
From Anaheim, CA
That looks awesome, i have the same car here in Anaheim California, was wondering if you guys know of a website i can order parts for it.like door panels.
Posted on: 2010/7/26 22:08
Cheers guys, Sway bar custom made, Door skins custome made as were interior door trim.
Well have shortened the R31 Housing, welded new mounts onto diff to suit leaf springs and now need to send long axle off to be shortened.
Sourced some U bolts and over half way to completing new plates for underside of spring where shock obsorber bolts on.
Also need to sort out Handbrake setup. So if anyone has a supplier for cables, let me know.
jpg  P1050043.JPG (31.07 KB)
2484_4c6d3aef3a7cc.jpg 448X336 px
Posted on: 2010/8/19 15:09
From mandurah
looking good jarrad ,when can i drop my diff around to be shortened haha
Posted on: 2010/8/20 0:32
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Well cant do much on diff till sort out handbrake and get axle back, so started on the front
U12 Pintarra Rotors are on with the Toyota s12+8 calipers. Its all bolted up, next step is to bleed the brakes. Ended up using the Stanza Girlock brake lines, which are a bit tight with the car jacked up, but hopefully it should be fine.
The worrying thing was the Stanza brakes I took off. The Rotor's were stuffed. Only about 70 % of the rotor had a indication of where the pads had been rubbing, and the front of the rotor has seen little work, while the back was badly scored. Not to mention they were very dull and not shiny.
jpg  strut.JPG (30.65 KB)
2484_4c7a5e4d8a80e.jpg 336X448 px
Posted on: 2010/8/29 14:21
Well the old Borgwarner 68 diff is out. Got a few more mods to do to the R31 diff and pickup the axle before can install it.
Bloody CA gearbox is leaking oil again, so have to have another look at whats going on there. Got a genuine gear stick boot to fit, but the non-genuine one is pretty clean so dont know what the go is with the oil leak. Have allready replaced 3 oil seals where the yoke goes in. Goin to use new yoke with the new tailshaft so maybe that will improve things.
jpg  2diffs.JPG (32.92 KB)
2484_4c824e021924d.jpg 448X336 px
Posted on: 2010/9/4 14:51
Gear box mounts
jpg  P1020091.JPG (25.23 KB)
2484_4c8cb4979c8ea.jpg 448X252 px
jpg  IMG_0053.JPG (20.68 KB)
2484_4c8cb4c10b560.jpg 252X448 px
Posted on: 2010/9/12 12:09
From mandurah
wow great work jarrad ! ,looks the goods brake and gearbox wise ,hopefully your problems will be solved when the diff goes in ,and good to hear that it is ready to go in ,not many people can shorten a diff with out a jig ,so its a real credit to be able to say you shortened your own diff ! great work !
Posted on: 2010/9/12 15:07
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Got the R31 diff in the car now, hand brake cables on order and looks like need to do wheel bearings now The drivers side axle has sideways movement when bolted all into place.
jpg  P1050378.JPG (34.96 KB)
2484_4ca33a4ceae27.jpg 448X336 px
jpg  P1050380.JPG (29.52 KB)
2484_4ca33a6999b3d.jpg 448X336 px
jpg  P1050381.JPG (31.00 KB)
2484_4ca33a7bca870.jpg 448X336 px
Posted on: 2010/9/29 14:09
