AE86 Inserts in B110 struts
From Trinidad and Tobago, West Indies
AE86 inserts fit b110 struts or 280zx struts?
I ask cause i am getting some mixed info
AE86 toyota inserts are ~43mm and b110 datsun inserts are ~45mm according to the wiki so they should work right??
stock datsun b110
418 body length / 631 Extended / 462 Collapsed
Stroke: 169mm (6.7 in)
AE86
Body length: 402mm
Extended length: 604mm
Extended minus Body: 202mm
Outside Diameter: 43.5mm
so these should swap, be shorter and have more travel right??
thanks
Posted on: 2010/7/21 7:27
My Datsun 1200 blog
Re: AE86 Inserts in B110 struts
From Taupo New Zealand
I haven't read the wiki but I think the datsun legs are 45mm OD. Therefore a 43mm insert will not fit inside them. 280ZX struts are 50.8mm OD so the 43mm inserts should fit in them but you'd want to measure the ID of the ZX leg first to make sure
Posted on: 2010/7/21 7:44
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Geelong
Don't know if this will help :
http://otomoto.com.au/HDSystems/sleevekits.htm
Posted on: 2010/7/21 10:16
hey thanks! that cleared it up - was going to buy some D2 32 way adjustable strut inserts from ebay for the AE86.. still watching em as i have both B110 and 280z struts
Posted on: 2010/7/21 14:18
My Datsun 1200 blog
From Geelong
Yeah my brother's got a 1972 Celica with supra struts, him and i are looking into them when the time is right
Posted on: 2010/7/21 14:47
Check out these coilovers from Stance
http://www.felonyperformance.com/stance-ae86.html
WOW!!
but at ~1700 USD!!!!
but you get full coilovers, camber/castor adjustable pillow ball top mounts and spacers.. hmmmmm too bad we cant use the rear spring..
Posted on: 2010/7/21 15:47
My Datsun 1200 blog
