If the uni joints are non repairable as such, there is surely a workaround, even if it required different flanges on the tailshaft to be welded in, and a uni joint with the right diameter cups, but able to be locked in place used in there. In other words it could be more expensive, but there'd have to be a workaround.
On the topic Kiri1 mentioned - I absolutely agree. A few years back, friends of the family had a bluebird (owned since new). It ended up seizing a uni. It was still 'driveable' but would shudder at anything above 50km/h. Being that I used to work on cars for a living, I offered to fix it for the cost of the uni, no probs. Instead of that, they took the attitude of 'i'll just drive it slowly and it'll be allright' and left it. It ended up tearing up the extension housing bush, then eventuaally bearings inside the box, as the ooutput shaft could 'flop about' as the tailshaft span. That $20 uni joint ended up costng them the gearbox (they actually paid to have it reco'd but it seemingly did something to either the output shaft or the bearings between it and the mainshaft, as it was still (relatively) sloppy thereafter and ended up vibrating again. All for a $20 part.
If you were in melbourne (and if they are still there, haven't been past in a while) then I'd suggest 'univeral driveshafts' near the lost dogs home in north melbourne (I'm not 100% but think it is gracie street. Not necessarily the cheapest guys in the world, but reliable and consistent with their work in my experience.
I haven't (so far!) had to replace the unis on my datsun coupe, so I haven't had a massively close look at them, but coming from a general revheead background, custom tailshafts and/or different flanges being welded on to each end, to enable things like a supra box behind a holden engine, going to a ford 9" diff, such work is commonplace. Surely there is a solution out there for datto 1200 enthusiasts?
Posted on: 2010/7/23 11:34
