(1) 2 3 »
#1 120Y - biggest brakes under 13" steelies?
Shifty Posted on: 2010/7/28 2:51
Hi guys
There's quite a few upgrades out there for the 120Y, currently I have S13 (CA) rotors & calipers with an adapter plate. Just can't really find an answer to my specific question, which is simply - what are the biggest/best bolt-on brakes you can fit to 120Y struts under 13" steelies?
I'm aware that my S13 brakes won't fit any more, so am looking for the best/biggest bolt-on option that will!
If at all possible I'm keen to keep my existing struts as I already have shocks, springs, etc sorted.
Thanks!
#2 Re: 120Y - biggest brakes under 13" steelies?
Posted on: 2010/7/28 3:09
s13 will fit with certian steelies, should fit with xp falcon sttelies, not old toyota ones- had the same issues with my 200b brakes- fit under certian 13's.
id stay with the s13 set up- much better braking performance if you want to keep 13's
#3 Re: 120Y - biggest brakes under 13" steelies?
matty Posted on: 2010/7/28 5:59
Hi Leigh
Have you thought about swapping to some 13" alloys?
CA18DET brakes will go under some 13" alloys.
Matt
#4 Re: 120Y - biggest brakes under 13" steelies?
A14force Posted on: 2010/7/28 6:54
After rolling on S13 brakes, I'd say just find some 13" alloys to clear them.
#5 Re: 120Y - biggest brakes under 13" steelies?
LittleFireyOne Posted on: 2010/7/28 9:16
or spend some coin and get the steelies rewelded to a negaive offset
#6 Re: 120Y - biggest brakes under 13" steelies?
b310gx Posted on: 2010/7/28 11:08
To answer the question you asked, the largest you can get under most 13 inch steel wheels are the stock 9 7/8 inch disc's from Stanza's or post november 78? 200B's which have the same disc & caliper sets as the stanza. This change in the 200B was so they could go back to 13 inch wheels. Hope this helps.
#7 Re: 120Y - biggest brakes under 13" steelies?
Shifty Posted on: 2010/7/29 2:32
Out of interest I'm wanting to run 180B hubcaps & whitewalls, so larger wheels and/or alloys aren't options.
If the CA brakes will fit under 13" then that's a no-brainer and I'll keep them, but from everything I've heard until now they need 14" steelies. XP falcon wheels, if they clear, I assume are a standard Falcon 5-stud anyway which isn't useful given that I'm running 4-stud Nissan brakes.
Perhaps Stanza/200B brakes will be the go. Do the rotors & calipers just bolt on to 120Y struts?
#8 Re: 120Y - biggest brakes under 13" steelies?
ssskiwi Posted on: 2010/7/29 2:40
XP Falcon sedans have 13" 4 stud from memory, whereas the commercial models i.e. ute, wagon had 5 stud for extra strength.
Futura and Fairmont had 14"..
#9 Re: 120Y - biggest brakes under 13" steelies?
DatsAndy Posted on: 2010/7/29 3:46
Had a similar drama as i wanted to use 13 inch steelies (Sunny, Stanza Steelies) but the S13 brakes and calipers didn't fit inside either of the above rims i tried even 14 inch alloy mags were a tight fit till i ground and smoothed a bit off the calipers. We ended just going sunny struts, 200b discs and VL commodore calipers.
#10 Re: 120Y - biggest brakes under 13" steelies?
Posted on: 2010/7/29 4:47
xm-xp falcons are 4 x 114.3 or 4.5 inch pcd (in imperial terms). perfect for 1200. i have used them heaps!
they were one of the few steel wheels that cleared my 200b set up. my superlights do too though.
most xp falcons switch to 5 stud for brake upgrades etc, you can find them cheap ish. i have 2 sitting here (one with a bit of gutter rash) that i found for $1 on ebay ages ago. will keep them as spares in case i ever need them.
They are getting hard to find but worth it if your dead set on 13's
id just go 14's or 13 inch mags that suit.
(1) 2 3 »
