Re: 45mm coil over conversion and insert choice
I figured bump steer spacers would be needed, Maddat does 25mm ones. Where'd you pick up the 30mm ones from?
How did the KYB's fit in the strut tube? Did you hone out the strut a bit or take the paint off the inserts?
Yeah I've had lowered cars with the LCA's near horizontal and they were #OOPS# house through corners so I want to avoid that completely
cheers again
Posted on: 2010/7/29 13:06
Subject Poster Date
     45mm coil over conversion and insert choice yz1975 2010/7/29 3:16
       Re: 45mm coil over conversion and insert choice benny 2010/7/29 4:44
         Re: 45mm coil over conversion and insert choice Kiri1 2010/7/29 6:46
           Re: 45mm coil over conversion and insert choice TUF-110 2010/7/29 9:26
             Re: 45mm coil over conversion and insert choice estyre 2010/7/29 9:57
               Re: 45mm coil over conversion and insert choice yz1975 2010/7/29 11:15
                 Re: 45mm coil over conversion and insert choice TUF-110 2010/7/29 11:21
                 Re: 45mm coil over conversion and insert choice yz1975 2010/7/29 11:24
                   Re: 45mm coil over conversion and insert choice benny 2010/7/29 12:13
                     Re: 45mm coil over conversion and insert choice PIGDOG 2010/7/29 12:38
                       Re: 45mm coil over conversion and insert choice benny 2010/7/29 12:45
       Re: 45mm coil over conversion and insert choice yz1975 2010/7/29 13:06
       Re: 45mm coil over conversion and insert choice benny 2010/7/29 23:43
       Re: 45mm coil over conversion and insert choice nick_m 2010/7/30 4:34
