Re: fitting trx rear brakes on 1000 front end. can this work?
From Wagga Wagga, NSW
Im getting stuck into this atm as im sick of drums, my setup consist of r31 rear disks and caliper brackets and vs commodore rear calipers
Posted on: 2010/8/3 3:44
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
When I asked the same thing about 8 years ago to Mammie motors
who are datsun 1000 specialists, they raced and owned about 40
of the things, they said that its more work with that bracket
than the sigma one. Any1 is open to prove them wrong.
Posted on: 2010/8/3 4:50
Well picked up all the bits today vs caliper and r31 rear disk fit nicely under a 13" not just to make up the bracket and plumb it in! progress ahoy!
Posted on: 2010/8/3 5:47
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From Perth
Small pad though
But anything an improvement
Posted on: 2010/8/3 11:06
Bracket modified everything bolted up now to plumb it all in!
Posted on: 2010/8/3 11:40
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From brisbane
Any chance of some photos mate?
Posted on: 2010/8/3 12:25
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
POB!
Anything that does away with trying to find a set
of 1200 coupe hubs is going in the right direction
Posted on: 2010/8/3 13:52
The modified bracket (ground a fair bit off to clear the lca after photo was taken) 1 hole bolts up and the other three were re-drilled
About 10 mm or slightly less clearance on the inside of my 13x6 jellybeans,
Posted on: 2010/8/4 11:48
From brisbane
Thanks very much mate!
Posted on: 2010/8/4 12:00
no worries matty :)
Posted on: 2010/8/4 12:03
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
« 1 2 3 (4) 5 6 7 »
