Busy day!!
Well rwd water parts got cleaned up and rwd alternator bracket painted ready for fitting..
Started by jacking up the car and removing the gearbox, ( THIS IS MY TORQUE STEER TAKE OF AT EASTERN CREEK DRAGS PIC!!!)
Gave the inside of the bellhousing a good thorough clean and degrease.. fun fun.
Ran down to the bolt shop to swap flywheel bolts because the ones i had purchased had too large heads and then could not tighten them next to the others once installed.. Southern Fasteners in kirrawee ( highly Recommended) swapped them over for free.. Also picked up some new bolts for the rwd water outlet while i was there.
Super Cheap for some locktight and some gasket paper to make some gaskets..
Attached my newly machined flywheel, clutch and pressure plate and then realised i only have one retaining spring for my thrust bearing/clutch fork so installation of the t-50 gearbox will have to wait....
HERE IS A COOL CARTOON, GOD I LOVE THE JAPANESE!!!!
Thanks to my mate puffy for assisting me on this whirlwind adventure today....
