part numbers for gear anyone?
Cannot find the ratios for these gears that im interested in
can anyone work out what the ratios are?
32230-H7200 1st Gear (32 t)/ Main Shaft
32250-H7200 2nd Gear (28 t)/ Main Shaft
32262-H7200 Ultra Close Ratio 3rd Gear (27 t)/ Main Shaft
32272-H7220 Ultra Close Ratio 4rd Gear (25 t)/ Main Shaft
32241-H7200 Main Shaft
Posted on: 2010/8/9 3:35
Re: part numbers for gear anyone?
We would need to know what the Teeth are on the cluster gear.
Is this for a Datsun gearbox?
Posted on: 2010/8/9 4:20
Oh, duh, I see you provided Nissan part numbers...OK, from the wiki the part numbers you list appear to be GX-5 gears (direct-fifth five speed).
Posted on: 2010/8/9 4:48
I seen provided Nissan part numbers, which is very useful and needed. It is very informative information. I get so many exactly information which I needed, It is really helpful for me.
Posted on: 2010/8/9 4:54
live blackjack
32230 is first gear
B110
* 32230-H7200 GEAR ASS'Y-1st, main shaft 5 speed
* 32250-H7200 GEAR ASS'Y-2nd, main shaft 5 speed
* 32260-H7200 GEAR ASS'Y-3rd, main shaft 5 speed
* 32270-H7200 GEAR ASS'Y-4th, main shaft 5 speed
This is the standard 5-speed, which is the wide ratio. Cluster gear is:
* 32213-H7200 GEAR-counter
Ratios are (from 56-Series_Transmission):
3.757 2.374 1.659 1.291 1.000 4.040
Posted on: 2010/8/9 5:08
so a stock useless 3.757 for the first :(
I was after a 2.8 or 2.6 for the first.
stocky is
3.757 (prefer 2.6)
2.169 (prefer 1.734 from 3 speed)
1.404 (prefer 1:1 from 3 speed)
1.000 (custom made 0.75)
Then an a14/15 would be perfect.
So I would like to spend 500aud for a 0.75 final
but would really need the 2.6 first at minimum
and could get the 3 speed from somewhere.
Posted on: 2010/8/9 12:08
Sounds like you want an overdrive five speed. The 63 has closer ratios
Posted on: 2010/8/9 17:09
prefer a 4 speed as the torque of the supercharged A will be plenty f
or the road and freeway. Also 63 series are too rare/expensive for the A
and would be cheaper with custom made 4th gear.
i just hope I can find a 2.6 for first and that the 1 to 1 from the
3speed fits the later 4 speed boxes.
Posted on: 2010/8/9 19:55
Edited by D on 2010/8/9 20:33:34
I wonder if there could be a way to weld up an overdrive gear from say
a corolla box or a 63L series box to the 56a final 4 speed.
Posted on: 2010/8/10 2:10
Sure there's a way. Dan Hall made a bunch of 60-series 4speeds with added overdrive. They were offered for sale right here several times over the last 12 months.
I don't know how he did it.
Posted on: 2010/8/10 2:57
