« 1 (2)
Re: datsun 1000 shockies. where do i get em?
From Gold Coast, Australia
Google Translate... Google knows russian.
Thanks for posing up another option with some pics, super cheap are going to have a look for a substitute to the nissan fronts for me, so knowing that torana ones fit with some mods is a good bit of info if they can't match them for me.
Posted on: 2010/8/16 22:06
www.datsun1000.com
1967 Datsun B10
From gold coast QLD.
Super Cheap!! What are you thinking?They would'nt have a clue unless it's a ford or holden.
What you need is Early 4 cylinder Torana/Viva fronts and swap the lower mounting brackets over,and for the rear i normally use Holden Rodeo rear's,there fairly firm but the right length.
Posted on: 2010/8/16 23:51
I have a set of Bilsteins on the front, unsure if they were modded though, got them recoed a while back.
Posted on: 2010/8/17 0:00
From Sydney
Just go to Pedders, BUT? There is a big difference between a Pedders store and a Pedders store who knows a little about susspension and gives a $hit about your little datto.
For my coupe I got comfort gas shocks for the rear and oils, but much bigger for the front. They even pressed the pins in and out of the front shocks.
I would take your car down and ask for shocks to fit. I'm with ya Bert, what are doing in Supercheap?
Posted on: 2010/8/17 0:02
From Wagga Wagga, NSW
What model early torana bert? Ive got a ta torana at home (4cylinder lj)
Posted on: 2010/8/17 3:14
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
HB Torana,and i think LC and LJ 4 cylinder torrie also.Obviously also the Viva the HB replaced from Vauxhall.
Posted on: 2010/8/17 4:40
Thank you Bert,
Yeah I know ... "Super Cheap"
This is my first datsun so im finding out the hard way that some parts are harder to source, super cheap had a listing for the gabriels so I ordered them.
To their credit The guy that I dealt with from the labrador super cheap store on the gold coast was extremely helpfull.
He has offered a refund on the gabriels for me, He also found out a little more about the oem shocks.
He said the fronts were made by KYB in japan from 1966 to 1969 only and are no longer avaliable through KYB. He also looked for substitutes in both gabriel and monroe but says they don't do any either.
I appreciate the effort.
On a more succesfull note,I got my rear shocks today and I can confirm that the BOGE are the same as the Nissan ones that were on my 1000 ute.
So I guess that has one end sorted out.
Below is what is stamped into the side of the BOGE rear shock absorbers.
2 9F11
1-0391-27-482-0
BOGE
Made in Western-Germany
Posted on: 2010/8/17 8:38
www.datsun1000.com
1967 Datsun B10
I took your advice Gav, Pedders have what we are looking for.
Front part #3029, $72 each. and they even had them in stock.
The fronts will need the rubber parts in the ends pressed out and swaped over to fit a 1000.
I didn't bother geting them to do this for me, as I still have to make new pins. (Mine are very bent). And I don't see me finishing my 1000 for a year or two. Plenty of time to get it sorted.
I think "Bert" has sugested pedders to press in new pins also.
Thanks for the info guys, It is members like you who make this site a pleasure to use.
There is also a listing for rear shocks and outer tie rod ends on the pedders website. Pedders catalogue
I asked for prices, rear shocks $91 each and outer rod ends $31 each.
Posted on: 2010/9/16 10:04
www.datsun1000.com
1967 Datsun B10
« 1 (2)
